![]() | Home > Technical > Cool box/fridge |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
Mine certainly turn off with the ignition, although it is a facelift but I don't think that should make any difference.
| DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264
Cheers Col
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
Mine does not turn off with the ignition and yes it will drain the battery in about 18 hours if left on. Last month I parked the car at 8 in the evening and left a map light and the fridge on and the car would not start at 11 the next day. Battery still had enough power to unlock the car, light up the dash and do a slow turn on the starter but not enough to fire the car and after the first go - nothing.
Thanks Garry
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9155
Strange. My old 08MY TDV8 used to turn the cooler cubby off when the ignition was off as does my 2012 SDV6. I seem to remember they did change the design of the cooler because of this issue. 2012 SDV6 - it's missing a couple of cylinders
Cheers RRSTDV8 |
| Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480
No problems on a 2012 sdv6 in terms of draining battery. |
Does that mean yours doesn’t turn off with the ignition Farther Jack ? |
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533
I`m sure my light is blue |
From what I have read on here Steve , some are blue and some green ?
Sorry, probably should have been clearer. If I stop and switch off with it running it has never killed my battery. In fact a few times I have forgotten it was on until noticing the subtle noise it makes when you are stopped in traffic for example. |
| syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412
I've just been out to mine (MY17), which has a factory fitted coolbox with a green light in the switch. It hasn't been used all day, the light is out (despite being switched on) and the cool box is at "room" temperature. On switching on the ignition, the green light illuminates. Mine is left permanently switched in the on position, with a couple of cans of diet coke and a couple of bottles of water in there, and I have never suffered from a flat battery even after leaving the car at the airport for a week whilst on holiday. RRS MY17 SDV6 AB
| Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567
This will probably confuse matters but mine has a blue light and I'm sure it does not switch off with the ignition but maybe some time after the ignition is switched off.
Hmmm the mystery continues |
| All times are GMT |
