![]() | Home > Maintenance & Modifications > Coolant leak RRSS 4.2 |
Take your time i just did mine and it took a bit of time to bleed it use the bleed valve on the header bottle and the other small one that is on the pipe coming up from the aux pump it took me a while to get heat into the heaters |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
It isn't the pipe connection.. the metal pipe that is attached to the bottom of the rad and curves around and towards the back has a pin hole in it. I had to remove most of the front of the car just to see it.
Nor was mine it was the pipe that feeds the supercharger which the pully had managed to damage but still a |
I've just been searching for the rad on the web and it seems to be the intercooler rad. I thought intercooler rads had air in them not water.. is the supercharger water cooled then? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5054 ![]() ![]() ![]() |
yeah supercharged ones are "chargecooled"
yes it is needed to help with the cooling as the supercharger is at the top of it's operating temp |
Well. The car is in pieces all over the drive... I've got the rad drained and disconnected but due to the stupid pipes it won't come out of the space..
Undo the slam panel at the top there are 4 star drives I think then pull it up out of the way |
rads are generally mounted together these days.
Got it out...
I removed- bumper, headlights, cross beam, plastic front rad cowling, plastic intake, top rad shroud and various other brackets etc.
It's not going to plan.. I ordered a new rad from Rimmer bros via UPS next day delivery. After waiting all day I got a call from someone several miles away saying they had a box delivered addressed to me.
Update if anyone is interested..
Well I think it's fixed.. just checked the coolant level this morning and it's the same as yesterday- for several days every morning I would have to put in .5 litre of coolant and I was thinking there was still a leak. I even put a sheet of cardboard under it overnight to check.
