![]() | Home > Technical > Overheating - Water Pump Wiring / Cooling Fan |
| Smartie Member Since: 31 Oct 2017 Location: Kummerfeld near Hamburg Posts: 6
Ok. thanx Geoff, limits it to sensor or fan! |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
heck your fan is working it should sound noisy when you start the car and then quiet and when iy starts to get hot you should hear it if it come on but it does sound like the viscous is maybe not working correctly if it only does it in traffic |
Thanx Geoff,
Some say if you can hold the fan when it’s supposed to be on when temp is high it means the viscous is knackered but never had the bottle to try to be honest |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
and if it chops your fingers off its working ok |
And that’s why I never did it |
and 350 quid for a new fan is cheaper than prosthetic fingers! |
| All times are GMT |
