Home > Technical > Overheating - Water Pump Wiring / Cooling Fan
Smartie
Germany 2007 Range Rover Sport Supercharged Java Black
Please can someone help????? My 2006 RRS Supercharged is over heating in traffic. Had water pump changed, but the fan does not seem to run up to full speed every time when I am in a german traffic jam (frequent occurrence)!!!!
I have heard the water pump wiring could be incorrect, or the fan sensor or viscous fan could be faulty.
Does anyone have any experience or solutions for this problem please????
If I need a new fan, any recommendations would be appreciated as there are so many available....
Thank in advance for your help.
Mark
Post #557571 Mon May 28 2018 11:01am
geoffsnook
The one you are talking about is the auxiliary pump for the supercharger which can come from the factory wired backwards which usually brings on limp mode when you are driving hard not in traffic so unlikely thats your issue Thumbs Up
Post #557574 Mon May 28 2018 12:17pm
Smartie
Ok. thanx Geoff, limits it to sensor or fan!
Post #557672 Tue May 29 2018 3:11pm
geoffsnook
heck your fan is working it should sound noisy when you start the car and then quiet and when iy starts to get hot you should hear it if it come on but it does sound like the viscous is maybe not working correctly if it only does it in traffic Thumbs Up
Post #557690 Tue May 29 2018 6:26pm
Smartie
Thanx Geoff,
it runs, but does not speed up each time it is hot. Have ordered a new complete fan. Thumbs Up
Post #557722 Wed May 30 2018 9:34am
geoffsnook
Some say if you can hold the fan when it’s supposed to be on when temp is high it means the viscous is knackered but never had the bottle to try to be honest Rolling with laughter
Post #557725 Wed May 30 2018 10:10am
and if it chops your fingers off its working ok
Post #557730 Wed May 30 2018 11:02am
geoffsnook
And that’s why I never did it
Post #557731 Wed May 30 2018 11:19am
Smartie
and 350 quid for a new fan is cheaper than prosthetic fingers! Rolling with laughter
Post #557809 Thu May 31 2018 5:20am
