![]() | Home > Technical > AC condenser replacement |
Half way there |
Yep the other one is the gearbox cooler |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
I got so far in but gave up. A bit disappointed but i dont have time now.
My lpg lube is where the spare battery would go but i know what you mean it is really tight i did mine at a friends garage so had access to what ever i needed but it was a pig and i did have to split the rad pack and drain off some of the coolant |
Update.
Just out of interest, what spare battery? |
Back left as you look from the front under the plastic cover thats where you could but a second battery |
Ah.. Mine has the lpg things under there and the flashlube is behind the coolant bottle front right. |
Got the car back today after having the condenser replaced. Total was £420.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
They don't have electric fans as these cars are designed to be used as slow speed in muddy fields.
Good grief. Can anyone do anything correctly.. Now ill have to take it back to get them to put it right. And im gonna wait while they do it. |
The plot thickens.. I took it back and he said it should have 900g in. So I called a Land Rover dealer and they said 900g too. I still think it should be 600g.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Just knoticed this thread.
