Home > Technical > AC condenser replacement
Page 2 of 3 <123>
geoffsnook
Half way there Thumbs Up
Post #556331 Sun May 13 2018 11:55am
Themoog
Ive had to back out. There is no way the condenser will come out without taking the other rads out or at least the front one.
Kids are on my back too so ive lost patience.
Off to a garage I think..
And there are 4 rads on mine. One is on the lower off side as well as 3 in the middle.
Post #556335 Sun May 13 2018 12:38pm
geoffsnook
Yep the other one is the gearbox cooler Thumbs Up
Post #556336 Sun May 13 2018 1:02pm
Themoog
I got so far in but gave up. A bit disappointed but i dont have time now.
Only one bottom bumper bolt survived. The rest had to be drilled and tapped. The front cross panel bolts were ok although very tight.
The biggest problem was the coolant bottle. Due to the lpg auto lube ecu in the way it was really difficult to move and unhook from behind the cross panel.
Like i said, the condenser will not come out without the other rads as all the pipework interferes.
If i can get it done for £500 or less all in then thats ok.
Post #556351 Sun May 13 2018 9:01pm
geoffsnook
My lpg lube is where the spare battery would go but i know what you mean it is really tight i did mine at a friends garage so had access to what ever i needed but it was a pig and i did have to split the rad pack and drain off some of the coolant Thumbs Up
Post #556353 Sun May 13 2018 9:05pm
Themoog
Update.
My friend who owns the local garage is going to replace the condenser for £360 all in so thats ok. Vast difference from £770..
Post #556403 Mon May 14 2018 1:02pm
geoffsnook
Post #556405 Mon May 14 2018 1:36pm
Themoog
Just out of interest, what spare battery?
Post #556410 Mon May 14 2018 2:08pm
geoffsnook
Back left as you look from the front under the plastic cover thats where you could but a second battery Thumbs Up
Post #556411 Mon May 14 2018 2:12pm
Themoog
Ah.. Mine has the lpg things under there and the flashlube is behind the coolant bottle front right.
Post #556413 Mon May 14 2018 2:17pm
Themoog
Got the car back today after having the condenser replaced. Total was £420.
Why doesn't the L320 have an electric fan as well as the the aircraft propeller behind the rad?
And another thing..I noticed on the invoice they have put in 900g of refrigerant. Now, the slam panel says 600g for front AC and 900g for rear AC. Mine has vents in the back but it's not adjusted back there so have they put in too much?
I didn't realise some L320 had adjustable climate in the rear.
Post #557219 Wed May 23 2018 3:38pm
They don't have electric fans as these cars are designed to be used as slow speed in muddy fields.
So the engine fan always pulls a bit of air thru.
The cleaver thing is that the ecu can command higher fan speeds.
I'm sure that fan is very powerful when it gets going!
Yeah they have put too much in. The high spec discoverys have the higher amount with a separate fan system at the rear of the car. (and air con pipes running to the rear!)
Post #557226 Wed May 23 2018 6:55pm
Themoog
Good grief. Can anyone do anything correctly.. Now ill have to take it back to get them to put it right. And im gonna wait while they do it.
Post #557232 Wed May 23 2018 8:40pm
Themoog
The plot thickens.. I took it back and he said it should have 900g in. So I called a Land Rover dealer and they said 900g too. I still think it should be 600g.
Who is right? Mine has no ac controls in the rear just two vents like my X5.
The slam panel sticker has two options 600g with arrows coming from front vents or 900g with arrows coming from front and rear vents.
I have never heard of or seen a RRSS with rear climate controls. Do they exist?
Post #557272 Thu May 24 2018 1:16pm
shepp
Just knoticed this thread.
Sorry the Moog, I could have shared a bit of info on replacing the condenser.
Did it on my old sc.
When you do get it stripped down, it does appear to be impossible to remove. you just need to loosen a couple of other auxiliaries and you can slide it out with a bit of a wobble.
 MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #557291 Thu May 24 2018 5:55pm
Page 2 of 3 <123>
