Home > Technical > Air suspension fault (of course)
Autocent
Denmark
Hello
Gets alarm for suspension fault. Diagnose tester shows fault C1A20-64 "Pressure in creases too slow when filling reservoir".
The car do not lower it self during a 24 hour period of parking, so no leaks there. With the diagnostic tester I can follow the gallery pressure.
When the car is started the pressure goes from 160 to 1600 kPa (1,6-16 bar) rather quick. When compressor stops the pressure drops as quick as it raised.
I am a little confused here, if gallery pressure is the same as reservoir pressure. I don't think the compressor is able to raise pressure i reservoir so quickly and I think if reservoir was leaking so much as the pressure drop indicates, I would hear it easily.
So what is going on ? Is it the compressor unit or reservoir valve blok which are faulty
Thanks for any qualified answer. Thumbs Up
Edit 10/5
Since no experts around. I am going to buy a new compressor unit and see if that do any good. It just seems that there are no volume in the system. since the pressure can go up and down so quick. On the other hand the fault C1A20-64 indicate a poor compressor ???? Could acess to reservoir be restricted ? Compressor interial leaking ? Reservoir full of water ? can that happen
Any good advice Big Cry
Post #556066 Wed May 09 2018 11:39am
Autocent
Denmark
Regarding buying a new compressor unit. Aftermarket compressors offered on e-bay. are they any good ?
Post #556224 Fri May 11 2018 8:42pm
paul2415
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I recently overhauled my 2010my compressor with a kit off eBay for total of £75, was not hard to do as long as you have some technical knowledge 👍🏻
Post #556238 Sat May 12 2018 8:22am
Autocent
Denmark
Do you recommend overhaul of the original one instead of buying a new aftermarket. ?
These aftermarket, probably China made, Are they OK ? It's half price to OEM
Post #556261 Sat May 12 2018 12:25pm
Brit Plumber
I’d rebuild with a kit if you have the time and patience. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #556264 Sat May 12 2018 1:16pm
paul2415
Re build is probably best, could advise you of how I did mine etc if it helps👍🏻
Post #556295 Sat May 12 2018 8:30pm
