![]() | Home > Technical > Air suspension fault (of course) |
Autocent Member Since: 09 May 2018 Location: Denmark Posts: 3 ![]() ![]() |
Regarding buying a new compressor unit. Aftermarket compressors offered on e-bay. are they any good ? |
paul2415 Member Since: 10 Nov 2014 Location: essex Posts: 59 ![]() ![]() ![]() |
I recently overhauled my 2010my compressor with a kit off eBay for total of £75, was not hard to do as long as you have some technical knowledge 👍🏻 |
Do you recommend overhaul of the original one instead of buying a new aftermarket. ?
I’d rebuild with a kit if you have the time and patience. 2019 5.0 SC SVA (Current)
Re build is probably best, could advise you of how I did mine etc if it helps👍🏻 |
