![]() | Home > In Car Electronics > Auto Detailer damaged the radio LCD display (SOLVED) |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595 ![]() ![]() |
Try a hairdryer |
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 ![]() ![]() |
That’s liquid behind the lcd screen (seems obvious)
Xrover Member Since: 08 Feb 2018 Location: Palm Desert Posts: 31 ![]() ![]() ![]() |
Red Arrow; That was the first thing I tried 2 days ago.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1557 ![]() ![]() ![]() |
My two-pennyworth: do the marks move when you press the screen, if so then it’s liquid. If no movement then damage to the screen caused by incorrect cleaner - may be?? Robin
Nothing moves or changes shape when I move my finger on the screen (with light pressure) 2006 LR3 HSE
So I would vote for screen damage as I suggested previously. I damaged my wife’s dell computer screen when I used a standard glass cleaner on it hence my suggestion. Perhaps they were cleaning the dashboard and didn’t blank off the screen and got overspray?? Anyone else heard of screen damage caused by incorrect solvent use?
Manual say's warm water and non detergent soap. 2006 LR3 HSE
Hmm. Yes. Not wishing to point the finger at your detailers, but the screen sounds like it would be susceptible to harsh chemicals......
I can't prove it but it was perfectly clear before I brought it to them.
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 325 ![]() ![]() |
Its liquid behind, check the two pictures, it is already different, so it moves and can be dried out. 2012 RRS HSE SDV6, BOURNVILLE 12/12-10/14
I decided to pull out the radio head unit and try to disassemble the LCD display to see if i could clean off the blotches.
Well done. Good work and good reference for others. Glad it’s sorted. |
Go back to the guy and tell him you fixed it yourself at no cost. And let him know he should be more careful with screens in the future. Ask him if you can see what dash cleaner he uses, I bet it’s a silicone based polish to give the plastic a sheen. Accidents do happen and he probably does believe it wasn’t him but if he can’t say 100% he protected the screen then he can’t 100% say it wasn’t him. An apology would be nice. 2019 5.0 SC SVA (Current)
