Home > Faults & Fixes > jeep wont start dash lighting up with warning messages
Page 2 of 4 <1234>
dulcie
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Hi, thanks for your help and advise much appreciated.
Firstly Saturday I took the battery off to charge ,and wrenched my back so been laid up resting it,but before I took battery off after replacing the radio and centre console, I tried the ignition and nowt but the warning message centre read normal no warning messages, so did the automatic gear selector centre below the clock, whereas before it read a large E
but I did notice that none of the usual lights that comes on when I turned the key to the second position to start.
The battery was reading eleven volts so I charged it over night and it read fully charged so I disconnected battery from charger and left the battery to see if the battery was loosing charge, over twenty four hours it went down to eleven and a half volts so I am now charging it again and going to see what it reads tomorrow,then leaving it while Wednesday to see if the battery looses charge,and if it needs replacing its under guarantee from the last owner,but my intention is to put the battery back on fully charged ,do I need to do another hard reset ? and check what you have told me, I am going to re place the brake switch as a matter of caution because everyone is blaming faulty brake switch on this forum.
By the way the radio doesent come on at all either
Post #553634 Mon Apr 09 2018 2:11pm
Paddi
Your battery is fubar'd. 2008 MY Java Black TDV8 HSE
Post #553635 Mon Apr 09 2018 2:25pm
jimbg
+1
Battery should be reading 12.6 volts. 11.5 is only 15% charged
[/img] 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #553637 Mon Apr 09 2018 2:38pm
dulcie
thanks for your help will get onto europarts under warranty you is famous on this forum so I must be privileged for you to help me thanks, much appreciated. what battery would you recommend.
Post #553639 Mon Apr 09 2018 2:53pm
dulcie
jimbg wrote:
+1
[/img]
Thank you very much for your help what battery would recommend paddi said the same thing my battery is a s3 or four bought in 20 16 four year guarantee gonna get a replacement and get one you recommend and paddy should say the same.
Post #553640 Mon Apr 09 2018 3:01pm
Paddi
This is a popular option:
https://www.tayna.co.uk/car-batteries/exide/ea1000/
There are cheaper choices on their site but a lot of people have ordered the Exide and seem very pleased with it.
Enter code 'D2BOYS' and if it is still valid, you'll get another 5% discount.
But check the dimensions before ordering just to be on the safe side Thumbs Up 2008 MY Java Black TDV8 HSE
Post #553642 Mon Apr 09 2018 3:28pm
dulcie
thas done me proud me duck, may the lord always keep thy bowels open, one love sir will get it sorted asap.Welll I will go to foot a my stairs,all that bother and bread I just went through and turns oot to be a low battery ,Hee by gum,who would a thought it eh,waint be able ta get owa this see thee.thanks your raite honourable kind sir may thee live long and prosper.
Post #553645 Mon Apr 09 2018 3:52pm
dulcie
got a new battery, did a hard reset, then connected the battery,she fired up so I went for a spin round the block, no flashing lights or warning messages,so I packed away all my tools and decided to go for a drive to make sure everything was okay,jeep wouldent start and warning messages, horn comes on when I lock on remote,indicators flashing both sides immobilizer light still on,checked brake lights all okay. HAS ANYBODY GOT ANY OTHER IDEAS,AS TO WHAT THE PROBLEM IS PLEASE.
Post #554187 Sat Apr 14 2018 6:27pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Cant offer any
Advice mate but if your looking for a good indy try Sheffieldprestige.co.uk They are based by the Virgin Active gym just off Broadlane Road in town. Used them myself and very happy to recommend them Thumbs Up Thumbs Up
Post #554194 Sat Apr 14 2018 7:52pm
dulcie
cheers for your referral but I am in Donny thanks anyway.
Post #554196 Sat Apr 14 2018 8:18pm
Socast
Sounds like something isn’t registering as being closed. Does it warn you that the bonnet etc. Is open when you start the car ?
Post #554202 Sat Apr 14 2018 9:43pm
dulcie
closed the bonnet,had aa out and think its sorted ,but will let forum know if the fault that aa diagnosed work.
Post #554219 Sat Apr 14 2018 11:37pm
dulcie
hi everyone who has been reading these posts, aa said the cause was two yellow wires either touching the body and shorting out or corroded located under the rear nearside rear inner wheel arch cove,. according to his diagnostic laptop with a picture I might add, PART OF CAN LINK.jacked car up COuld see two wiring looms and disconnected them and cleaned they were fine ,pins okay lowered the jeep and no faults, cd worked and sat nav, fourxfour lined up fine after starting her up, highered and lowered suspension but noticed when I highered it, the jeep went bach to normal height by itself was chuffed cd playing ,no faults or warning lights ,then turned her off went to start her again after about five minutes, warning lights and message both side indicators on, engine fault shutdown on radio no radio or cd ,engine wont start ONCE AGAIN caution lean when cornering ,CAN ANYONE DO OWT TO HELP ME SOLVE THIS INTERMITTENT STARTING AND ALL OTHER FAULTS AND WARNING LIGHTS PROBLEMS PLEASE THANKS IN ADVANCE.
Post #554687 Sat Apr 21 2018 3:50am
Eaters
Have you checked your alternator yet? Perhaps the AA did it? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #554693 Sat Apr 21 2018 8:47am
dulcie
hi eaters, yes aa checked alternator ,starter, battery, and said engine was fine. been looking and thinking about buying a optical loop as well as a diagnostic tool , carsoft lr2 just come out, to re programme,as I took two rear wiring loom apart and cleaned ,wires were fine.
Post #554695 Sat Apr 21 2018 9:13am
Page 2 of 4 <1234>
