![]() | Home > Faults & Fixes > jeep wont start dash lighting up with warning messages |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Your battery is fubar'd. 2008 MY Java Black TDV8 HSE
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1924
+1
| dulcie Member Since: 04 Apr 2018 Location: sth yorks Posts: 33
thanks for your help will get onto europarts under warranty you is famous on this forum so I must be privileged for you to help me thanks, much appreciated. what battery would you recommend. |
Thank you very much for your help what battery would recommend paddi said the same thing my battery is a s3 or four bought in 20 16 four year guarantee gonna get a replacement and get one you recommend and paddy should say the same. |
This is a popular option:
thas done me proud me duck, may the lord always keep thy bowels open, one love sir will get it sorted asap.Welll I will go to foot a my stairs,all that bother and bread I just went through and turns oot to be a low battery ,Hee by gum,who would a thought it eh,waint be able ta get owa this see thee.thanks your raite honourable kind sir may thee live long and prosper. |
got a new battery, did a hard reset, then connected the battery,she fired up so I went for a spin round the block, no flashing lights or warning messages,so I packed away all my tools and decided to go for a drive to make sure everything was okay,jeep wouldent start and warning messages, horn comes on when I lock on remote,indicators flashing both sides immobilizer light still on,checked brake lights all okay. HAS ANYBODY GOT ANY OTHER IDEAS,AS TO WHAT THE PROBLEM IS PLEASE. |
| scousefly Member Since: 24 Jan 2015 Location: sheffield Posts: 248
Advice mate but if your looking for a good indy try Sheffieldprestige.co.uk They are based by the Virgin Active gym just off Broadlane Road in town. Used them myself and very happy to recommend them |
cheers for your referral but I am in Donny thanks anyway. |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594
Sounds like something isn’t registering as being closed. Does it warn you that the bonnet etc. Is open when you start the car ? |
closed the bonnet,had aa out and think its sorted ,but will let forum know if the fault that aa diagnosed work. |
hi everyone who has been reading these posts, aa said the cause was two yellow wires either touching the body and shorting out or corroded located under the rear nearside rear inner wheel arch cove,. according to his diagnostic laptop with a picture I might add, PART OF CAN LINK.jacked car up COuld see two wiring looms and disconnected them and cleaned they were fine ,pins okay lowered the jeep and no faults, cd worked and sat nav, fourxfour lined up fine after starting her up, highered and lowered suspension but noticed when I highered it, the jeep went bach to normal height by itself was chuffed cd playing ,no faults or warning lights ,then turned her off went to start her again after about five minutes, warning lights and message both side indicators on, engine fault shutdown on radio no radio or cd ,engine wont start ONCE AGAIN caution lean when cornering ,CAN ANYONE DO OWT TO HELP ME SOLVE THIS INTERMITTENT STARTING AND ALL OTHER FAULTS AND WARNING LIGHTS PROBLEMS PLEASE THANKS IN ADVANCE. |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
Have you checked your alternator yet? Perhaps the AA did it? Robin
hi eaters, yes aa checked alternator ,starter, battery, and said engine was fine. been looking and thinking about buying a optical loop as well as a diagnostic tool , carsoft lr2 just come out, to re programme,as I took two rear wiring loom apart and cleaned ,wires were fine. |
| All times are GMT |
