Home > Technical > Adaptive dynamics fault
Bulldog
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Hi My RRS 2010 3,6 has developed an adaptive dynamics fault Censored
I have checked the fluid level and that is OK. Do I check the ride height sensors & wires next ? on the 4X4 screen it all shows as normal (no red lights).
Post #554640 Fri Apr 20 2018 9:15am
What's the fault? Do you have fault codes or just an error on the dash? 2012 SDV6 - it's missing a couple of cylinders
Post #554651 Fri Apr 20 2018 11:32am
Bulldog
Only message on dash it only happened last night i left it overnight as i wasnt sure if it was heat related but it was there this morning also. will hopefully grab codes later today..
Post #554652 Fri Apr 20 2018 11:49am
Buckster
Mine has been doing this intermittently for a while now, sometimes when I switch it off and start it again it disappears. Mine is a rear height sensor code. Thats where I would be looking first Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #554668 Fri Apr 20 2018 4:33pm
Bulldog
Hi
Had codes read and it’s rear right ride height sensor. Going to order a new one. Tried to get old one out to check part number but 2small torx head screws are just spinning Censored looks like I will need to be brutal and break sensor apart !!!!!
Post #554670 Fri Apr 20 2018 5:13pm
Buckster
I believe you will need to set up height again if replacing one, thats what i was told Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #554671 Fri Apr 20 2018 5:17pm
Bulldog
Yes I know that calibration of suspension height is required filling the change. I cannot understand why the 4x4 screen was showing normal orange mark by ride height ? If sensor or wire is faulty surely it would show as red ?
Post #554673 Fri Apr 20 2018 5:36pm
