![]() | Home > Technical > Adaptive dynamics fault |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9090 ![]() ![]() ![]() |
What's the fault? Do you have fault codes or just an error on the dash? 2012 SDV6 - it's missing a couple of cylinders
Bulldog Member Since: 11 Jul 2013 Location: Solihull, West Mids Posts: 112 ![]() ![]() ![]() |
Only message on dash it only happened last night i left it overnight as i wasnt sure if it was heat related but it was there this morning also. will hopefully grab codes later today.. |
Mine has been doing this intermittently for a while now, sometimes when I switch it off and start it again it disappears. Mine is a rear height sensor code. Thats where I would be looking first |
Hi
I believe you will need to set up height again if replacing one, thats what i was told |
Yes I know that calibration of suspension height is required filling the change. I cannot understand why the 4x4 screen was showing normal orange mark by ride height ? If sensor or wire is faulty surely it would show as red ? |
