![]() | Home > Faults & Fixes > Red suspension light coming in when going round left corner |
| Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533
Do you mean this one...but in red?
| Nico2104 Member Since: 10 Jun 2017 Location: Derby Posts: 58
Hi yes that's it, mine sometimes comes on yellow saying, "fault when cornering" but it's mainly red when it does it. It's done it every now and again for ages but with all the wet weather it's doing it all the time but only when turning left. Cheers |
And does it say max speed 30mph....and feel like you`re driving a clown car? Steve. |
It doesn't lower the suspension or put it into limp mode. It drives normal and suspension stays in normal height. Cheers |
So yours is the ride height warning light then...not the tippy over one |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
Checked the fluid level yet |
Yes mate, 1st thing we checked was the fluid level, the suspension light comes on only when going round a left corner or if you park and the car is leaning to the left. Compressor seems fine, car pumps up and goes down really well. It's just the fact it does it mostly when the roads are wet and when going round left bends/corners. Got us baffled to be honest. |
Got any codes for us |
If you drive it and it comes on do any of the sensors on the 4x4 screen go red or have you not looked yet as i think they are just generic codes you could do with a read from a land rover specific code reader |
All sensors are reading fine, I did have a height sensor replaced at a place about 2 months ago and the side they fitted to has sat 20mm lower than the others. I think if no luck on here I'll get I booked in somewhere next week. I just don't want them telling me it's this and it's that as I've had it before where they tried to charge me a fortune for something that didn't cost much at all. Cheers |
Have a look at this topic does any thing fit with your issue's |
Nothing really in thereatched mine, the car drives absolutely fine even when the red suspension light is on. If I switch the car off it dissappear a until I swing round d a left corner but like I say if its been dry for a few days it doesn't really ever do it. Its more when it's wet or been a freezing/damp night or day. I did speak to a place I have used but there a 4 hour drive from me, they said it sound likes maybe the wiring that goes to the lock in the back of the car as its exposed and common for the wiring having breaks especially as it comes on more in the wet. |
