Home > Technical > P0128-00 (E8) 2007 RRS
Wacko
Canada 2007 Range Rover Sport 4.4 V8 HSE Chawton White
Hello,
I am in Canada with a 2007 4.4 Petrol V8 RRS
I am getting a check engine light and code P0128-00 (E Coolant thermostat (coolant temperature below thermostat regulating temperature). I have replaced thermostat and it appeared to be bad as seal was folded over. Still was throwing code so I replaced the coolant temp sensor. It still doesn't seem to be reaching proper temp, maxing out around 68 degrees Celsius.
The radiator cooling fan seems to be running all the time. Is this normal or should it only run at a certain temp?
I have the Gap Diagnostic tool to monitor and check ecu's
The temperature here right now is around +8 degrees Celsius
Anyone dealt with this issue? Any suggestions on where to go next?
Thanks
Post #551367 Wed Mar 14 2018 5:28pm
geoffsnook
The cooling fan should not run continually it should come on when first started then only come on when needed if its on all the time you will here it making quite a noise Thumbs Up
Post #551378 Wed Mar 14 2018 7:36pm
are they not engine driven fans (vicious)? like the diesel ?
Try turning the air con off for a few days (press eco) and see if that helps.
Post #551379 Wed Mar 14 2018 7:57pm
shepp
Hello Wacko
The electro viscose fan should only come on when hot.
With the engine switched off and cool, you should be able to easily rotate the fan, it should 'freewheel' when cold.
My previous 4.2 SC fan would come on due to the sc pump been wired backwards and the charger getting warm, but not the engine. So it is worth checking if there may be any other temp sensors causing the issue. Obviously it has no SC, but I am not fully familiar with the 4.4 and its sensors MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #551381 Wed Mar 14 2018 8:05pm
Wacko
How long should it run after start up?
Post #551392 Wed Mar 14 2018 8:57pm
mechanical ones will always move around
But you should notice a difference to the speed when you turn the air con on and off.
Post #551396 Wed Mar 14 2018 9:27pm
geoffsnook
I here my for about 10-20 seconds quite loud then it’s all quiet Thumbs Up
Post #551398 Wed Mar 14 2018 9:50pm
Wacko
Any recommendations on what would cause my fan to run constantly? Is it a bad relay or clutch? Do I need to replace the fan?
Any help appreciated
Thanks
Post #551404 Wed Mar 14 2018 11:15pm
Wacko
A little update. My fan does appear to be spinning when ever engine is running however it isn't overly loud. I unplugged it and started the engine and it continued to spin. With the engine off I can spin the fan with my had but there is slight resistance. Is this normal or should it free spin with no resistance.
All the information I find is regarding either a no electronic fan with just a clutch or an electric fan with no clutch. This seems to be both?
Post #551466 Thu Mar 15 2018 3:39pm
Socast
Hi Wacko,
The fan is an electronic viscous fan, because of the slight resistance you can feel when turning the fan with the engine stopped the fan will spin at all times when the engine is running. However you can hear when the fan is engaged (electronically) as the fan will make significantly more noise (air movement noise, not mechanical) than normal.
When you start the car for the first time the fan is engaged for around a minute or so (it depends on ambient temperature) it will then engage intermittently as an when the engine temps dictate.
My money would be on the system being air locked after the thermostat change. There are a couple of bleed screws, one close to the thermostat housing and a second on-top of the header tank (both screws are identical so that should aid you in locating the one near the thermostat).
If that doesn't work you could try putting come card board in-front of the radiator (between the grill and radiator) this will raise system temps and allow you to see if it's a sensor or not.
Post #551471 Thu Mar 15 2018 4:13pm
Wacko
Socast,
Thanks very much. That is what I needed to hear, so I can eliminate the fan as the problem.
Cheers 🍻
Post #551477 Thu Mar 15 2018 4:53pm
geoffsnook
The V8's can be a pig to bleed Thumbs Up
Post #551514 Thu Mar 15 2018 7:42pm
Wacko
Could air in the system cause too much cooling? My problem is the engine isn't getting up to proper engine temperature
Post #551517 Thu Mar 15 2018 7:44pm
