![]() | Home > Technical > P0128-00 (E8) 2007 RRS |
The cooling fan should not run continually it should come on when first started then only come on when needed if its on all the time you will here it making quite a noise |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5097 ![]() ![]() ![]() |
are they not engine driven fans (vicious)? like the diesel ?
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Hello Wacko
Wacko Member Since: 03 Sep 2016 Location: Chilliwack BC Posts: 6 ![]() ![]() ![]() |
How long should it run after start up? |
mechanical ones will always move around
I here my for about 10-20 seconds quite loud then it’s all quiet |
Any recommendations on what would cause my fan to run constantly? Is it a bad relay or clutch? Do I need to replace the fan?
A little update. My fan does appear to be spinning when ever engine is running however it isn't overly loud. I unplugged it and started the engine and it continued to spin. With the engine off I can spin the fan with my had but there is slight resistance. Is this normal or should it free spin with no resistance.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Hi Wacko,
Socast,
The V8's can be a pig to bleed |
Could air in the system cause too much cooling? My problem is the engine isn't getting up to proper engine temperature |
