Home > Technical > Parking sensor testing
Gandalf
Hi all can you test the parking sensors with the Gap tool mine are not working Banging Head .
Peter If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling
Think I see a pattern here
Post #545314 Tue Jan 09 2018 6:08pm
yes you can.
1) You can read fault codes and see which ones are complaining.
2) If the system is working, you can view the distance to an object they are each reporting.
Post #545315 Tue Jan 09 2018 6:17pm
Gandalf
Where is it had a look but couldn't find the section. Only came this morning so got L plates on ATM could find my way round a nano on my TD5 but this Confused also cleared all the historical faults so see if anything comes up. If it ain't broken down it soon will
Post #545334 Tue Jan 09 2018 8:11pm
What's the issue with them.
Post #545335 Tue Jan 09 2018 8:15pm
Gandalf
Continuous beep on startup light on the dash is flashing and no sound. Smacked into a gate post this morning Banging Head luckily just chipped some paint off the bumper corner thought I'd smashed it at first. If it ain't broken down it soon will
Post #545339 Tue Jan 09 2018 8:24pm
Read the fault codes then
Post #545341 Tue Jan 09 2018 8:53pm
Gandalf
Will do tomorrow. If it ain't broken down it soon will
Post #545345 Tue Jan 09 2018 9:55pm
Gandalf
Hi Andy cleared all the faults took it for a run this is what has come up.
It did struggle to start battery only had 11.5 volts so some might be because of this will keep an eye on it.
Model L320 - Range Rover Sport 2006
Vehicle scanned on 10 Jan 2018 1:41:13 p.m.
IIDControl 2.9.4.5 Android - IIDTool BT V3.0 B2481
Audio System
• U1A03-62 (2B) Vehicle configuration parameter - Algorithm based failure - signal compare failure
( on 08-10-2016 01:27:33 at 94983 mi )
Body Control
• B1B02-28 (2F) Low frequency coil - General signal failure - signal bias level is out of range/zero adjustment failure
( on 07-10-2016 21:36:16 at 94950 mi )
• B1B70-01 (2E) Local interconnection network bus circuit 2 - General failure information - general electrical failure
( on 07-10-2016 21:44:28 at 94950 mi )
• B1C57-14 (6C) Passive start ignition relay coil circuit - General electrical failure - circuit short to ground or open
( on 07-10-2016 21:35:38 at 94950 mi )
• U0155-87 (2E) Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
( on 07-10-2016 21:43:56 at 94950 mi )
Engine TDV6
• P0404-00 (6C) Exhaust gas recirculation control - circuit range/performance
• P0299-00 (6C) Turbo/supercharger underboost
• P1935-00 (28) Brake switch/sensor signal
Instrument Pack
• U0159-87 (2E) Lost communication with parking assist control module - Bus signal/message failure - missing a message
Parking Aid
• B1B38-01 (68) Front right inner sensor - General failure information - general electrical failure
Ventilation
• B1B74-00 (28) Front foot-defrost mode stepper actuator
( on 07-10-2016 22:41:07 at 94950 mi )
• B1B75-00 (68) Front foot-face mode stepper actuator
• B1B76-00 (28) Front left air blend stepper actuator
( on 07-10-2016 22:41:08 at 94950 mi )
• B1B77-00 (28) Front right air blend stepper actuator
• B1B78-84 (2F) System pressure - Bus signal/message failure - signal is below allowable range
( on 07-10-2016 21:37:09 at 94950 mi ) If it ain't broken down it soon will
Post #545408 Wed Jan 10 2018 2:56pm
Lindab
Don't think I shall be buying a fault code reader. Ignorance is bliss Whistle
Post #545409 Wed Jan 10 2018 3:02pm
Gandalf
Don't think I shall be buying a fault code reader. Ignorance is bliss.
Nah it'll stop me getting bored When I get the hang of the bleedy thing If it ain't broken down it soon will
Post #545416 Wed Jan 10 2018 3:49pm
Stevepd
Rolling with laughter 2006 2.7 TDV6 HSE in Cairns Blue.
Post #545418 Wed Jan 10 2018 3:59pm
Paddi
Think you can safely ignore the first four under 'Ventilation' I always see those fault codes and the HVAC works fine. Seem to remember it was no less than the supremo Disco Mikey who pointed that out some time back?
The fifth looks as if it is telling you the air conditioning has insufficient pressure because the refrigerant has leaked out. If you are lucky it just needs a regas. 2008 MY Java Black TDV8 HSE
Post #545424 Wed Jan 10 2018 4:48pm
Gandalf
@Paddi
I am ignoring them for the time being, the engine ones not so sure
Engine TDV6
• P0404-00 (6C) Exhaust gas recirculation control - circuit range/performance EGR removed/blanked thought you didn't need a software patch on the 05s
• P0299-00 (6C) Turbo/supercharger underboost :blub: hope it's only the turbo pipes, intercooler, sensor cleaning or actuator sticking
• P1935-00 (28) Brake switch/sensor signal On order £10 JGS 4X4 If it ain't broken down it soon will
Post #545426 Wed Jan 10 2018 5:01pm
Post #545440 Wed Jan 10 2018 7:10pm
Gandalf
My thoughts exactly just thought I'd post as it also mentioned U0159-87 (2E) Lost communication with parking assist control module - Bus signal/message failure - missing a message just wanted confirmation it was the sensor. Thanks again Andy Thumbs Up If it ain't broken down it soon will
Post #545442 Wed Jan 10 2018 7:14pm
