![]() | Home > Technical > Parking sensor testing |
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 ![]() ![]() ![]() |
Hi all can you test the parking sensors with the Gap tool mine are not working |
Where is it had a look but couldn't find the section. Only came this morning so got L plates on ATM could find my way round a nano on my TD5 but this |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5041 ![]() ![]() ![]() |
What's the issue with them. |
Continuous beep on startup light on the dash is flashing and no sound. Smacked into a gate post this morning |
Read the fault codes then |
Will do tomorrow. If it ain't broken down it soon will
Hi Andy cleared all the faults took it for a run this is what has come up.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 924 ![]() ![]() |
Don't think I shall be buying a fault code reader. Ignorance is bliss |
Don't think I shall be buying a fault code reader. Ignorance is bliss.
Think you can safely ignore the first four under 'Ventilation' I always see those fault codes and the HVAC works fine. Seem to remember it was no less than the supremo Disco Mikey who pointed that out some time back?
@Paddi
Front right inner sensor |
My thoughts exactly just thought I'd post as it also mentioned U0159-87 (2E) Lost communication with parking assist control module - Bus signal/message failure - missing a message just wanted confirmation it was the sensor. Thanks again Andy |
