Home > Technical > replacement engine
Nige
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
replacement engine
just getting ready to put the new lump in BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
two discos v6 off contract (for sale) before they go to scrap
Post #540087 Fri Nov 03 2017 8:33pm
Nige
back on the road in a bit
Post #540090 Fri Nov 03 2017 8:39pm
BKHK
Wow, that’s quite a lump! Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #540123 Sat Nov 04 2017 2:55pm
Nige
yep,,getting the body off aint as easy as it looks Sad BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #540140 Sat Nov 04 2017 5:41pm
Disco_Mikey
Report back in 2 hours, with the body off Thumbs Up
Post #540146 Sat Nov 04 2017 6:14pm
Disco_Mikey
That looks like an EU4 engine, fitted with DR
Presumably it's going into the 55 reg car? Question
Post #540147 Sat Nov 04 2017 6:17pm
Nige
its going in a 05 BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #540148 Sat Nov 04 2017 6:20pm
Disco_Mikey
In that case, it's not a straight swap...
Fuel pump + bracket + rear belt + covers
Injectors
Fuel lines
Wiring loom
Breather system
Alternator + mounting bracket
EGR valves, coolers and pipework
PAS pump and brackets
And it REALLY needs a new oil pump before fitting
Post #540149 Sat Nov 04 2017 6:27pm
Nige
yep ,there is lots to do, could not believe how different the engines are,,i have two engines but the one pictured only has 50 thou on it BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #540150 Sat Nov 04 2017 6:32pm
Nige
just a thought? when its all swapped over will it need coding ?????? BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #540151 Sat Nov 04 2017 6:34pm
Disco_Mikey
No Thumbs Up
Post #540154 Sat Nov 04 2017 8:09pm
Nige
cheers mikey,will let you know how i go on,,BLOODY RANGE ROVERS Twisted Evili thought my discos were bad enough BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #540155 Sat Nov 04 2017 8:16pm
Disco_Mikey
They are just as bad. Done 3 last month Laughing
Post #540156 Sat Nov 04 2017 8:20pm
Nige
my old mans mate told me the 2.7 tdv6 was a french engine ( is that true? ) or was it a bit of northern pub banter BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
Post #540164 Sat Nov 04 2017 9:29pm
Disco_Mikey
PSA collab, developed between Ford, Peugeot + Citroen Thumbs Up
Post #540168 Sat Nov 04 2017 11:02pm
