![]() | Home > Technical > replacement engine |
Nige Member Since: 29 Oct 2017 Location: lancashire Posts: 82 ![]() ![]() ![]() |
back on the road in a bit
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942 ![]() ![]() ![]() |
Wow, that’s quite a lump! Gone - 2008 Stornoway Grey RRS 2.7 TDV6
yep,,getting the body off aint as easy as it looks |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Report back in 2 hours, with the body off |
That looks like an EU4 engine, fitted with DR
In that case, it's not a straight swap...
yep ,there is lots to do, could not believe how different the engines are,,i have two engines but the one pictured only has 50 thou on it BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
just a thought? when its all swapped over will it need coding ?????? BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
No |
cheers mikey,will let you know how i go on,,BLOODY RANGE ROVERS |
They are just as bad. Done 3 last month |
my old mans mate told me the 2.7 tdv6 was a french engine ( is that true? ) or was it a bit of northern pub banter BUILDER PRETENDING TO BE A MECHANIC (give me some bricks and i will build you a house)
PSA collab, developed between Ford, Peugeot + Citroen |
