| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > Transfer box replacement |
| Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251      | R1CHD,
|  Wed Oct 11 2017 7:26am |
| R1CHD Member Since: 27 Aug 2017 Location: Warminster Posts: 32      | Hi Steve,
|  Wed Oct 11 2017 7:44am |
| GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420    | Do an oil change first, it will tell you if the problem lies with the transfer box. Your issue could be something else, possibly the torque converter. Little point in shelling out for a new transfer case when a relatively cheap inspection of the oil may rule out a fault. | ||
|  Wed Oct 11 2017 7:51am |
| R1CHD Member Since: 27 Aug 2017 Location: Warminster Posts: 32      | Hi Nige,
|  Wed Oct 11 2017 9:01am |
 Sorry didn't mean that to sound like a loaded question (re-reading it it sound just that!). Steve. | ||
|  Wed Oct 11 2017 9:29am |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329    | Does it make the same noise in both High and Low range ? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
|  Wed Oct 11 2017 9:47am |
 Hi, a lack of metal in the oil is a good sign. Ive also seen reports on the internet about this light throttle resonance and some saying they cured it with a new torque converter. When it is happening, does it the noise disappear instantly with slight increase in throttle? There is a thread somewhere within rrsport of a similar complaint and a dealer reported it as a characteristic of the gearbox/torque converter, the noise occurring at the point when the torque converter lock up is not quite engaged. | ||
|  Wed Oct 11 2017 10:07am |
|  Wed Oct 11 2017 11:09am |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Here's the guide you were looking for:
|  Wed Oct 11 2017 11:49am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | It's a gearbox related noise
|  Wed Oct 11 2017 12:03pm |
| GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420    | Maybe a gearbox flush first then, not that its a guaranteed cure but worth a go. | ||
|  Wed Oct 11 2017 12:22pm |
| R1CHD Member Since: 27 Aug 2017 Location: Warminster Posts: 32      | Thanks for the info I wonder if its worth contacting Land Rover to see if there are any software updates available for the gearbox or engine that could help with this or I have heard that an independent ecu remap has cured similar faults but I have no proof of this, does anyone have an idea on the cost of replacing a torque converter?
|  Wed Oct 11 2017 12:32pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | About £1200ish
|  Wed Oct 11 2017 5:42pm |
| R1CHD Member Since: 27 Aug 2017 Location: Warminster Posts: 32      | Thanks for the info I think I’ll just let it lie for now | ||
|  Thu Oct 12 2017 8:11pm |
| Posting Rules
