![]() | Home > Faults & Fixes > Transfer box replacement |
R1CHD,
R1CHD Member Since: 27 Aug 2017 Location: Warminster Posts: 32 ![]() ![]() ![]() |
Hi Steve,
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Do an oil change first, it will tell you if the problem lies with the transfer box. Your issue could be something else, possibly the torque converter. Little point in shelling out for a new transfer case when a relatively cheap inspection of the oil may rule out a fault. |
Hi Nige,
Sorry didn't mean that to sound like a loaded question (re-reading it it sound just that!). Steve. |
Does it make the same noise in both High and Low range ? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Hi, a lack of metal in the oil is a good sign. Ive also seen reports on the internet about this light throttle resonance and some saying they cured it with a new torque converter. When it is happening, does it the noise disappear instantly with slight increase in throttle? There is a thread somewhere within rrsport of a similar complaint and a dealer reported it as a characteristic of the gearbox/torque converter, the noise occurring at the point when the torque converter lock up is not quite engaged. |
Hi
Here's the guide you were looking for:
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4500 ![]() ![]() ![]() |
It's a gearbox related noise
Maybe a gearbox flush first then, not that its a guaranteed cure but worth a go. |
Thanks for the info I wonder if its worth contacting Land Rover to see if there are any software updates available for the gearbox or engine that could help with this or I have heard that an independent ecu remap has cured similar faults but I have no proof of this, does anyone have an idea on the cost of replacing a torque converter?
About £1200ish
Thanks for the info I think I’ll just let it lie for now |
