![]() | Home > Technical > tdv6 timing belt |
nebc100 Member Since: 27 Aug 2017 Location: Altlinster Posts: 113 ![]() ![]() ![]() |
Hello all,
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
Dayco do make belts for ford so it is possible that dayco made the original. |
Would the original have LR marked on it or Dayco? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
Yes.
Thanks for the answer.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Unless something is up you cannot really tell if the belt has been replaced or not just by looking at them. Normally a used belt really does not show any wear and often looks like new - it is inside that changes have taken place - if in doubt change and go the Dayco. 07MY RRS TDV6
Thanks for the info.
