Home > Technical > tdv6 timing belt
nebc100
Luxembourg 2008 Range Rover Sport TDV6 HSE Java Black
tdv6 timing belt
Hello all,
Just a small question.
Who makes the original LR timing belt?
I have just replaced mine with a Contitech belt, but the one that was in it was a Dayco.
It had been replaced before I bought the car, but I didn't know when so I replaced it anyway.
But... is Dayco an original?
Thanks.
Nick
Post #537911 Mon Oct 09 2017 8:49pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Dayco do make belts for ford so it is possible that dayco made the original.
Post #537929 Tue Oct 10 2017 5:41am
nebc100
Would the original have LR marked on it or Dayco?
Post #537933 Tue Oct 10 2017 6:14am
Yes.
Its easy to get Dayco as a replacement too
Post #537952 Tue Oct 10 2017 11:07am
nebc100
Thanks for the answer.
I know that it is easy to get a Dayco. I simply was trying to determine for sure if the timing belt in my RRS had been replaced.
Going by the condition, I was pretty sure that it had been replaced (going by the condition), but was not sure. The name on the belt was Dayco, so I doubted that this was the original one, but I just wanted to be sure.
Post #537956 Tue Oct 10 2017 11:36am
rich_sargie
Most original belts carry both the car and belt manufacturers name together.
Then juts the belt manufacturers name in the aftermarket
Post #537973 Tue Oct 10 2017 1:09pm
garrycol
Australia
Unless something is up you cannot really tell if the belt has been replaced or not just by looking at them. Normally a used belt really does not show any wear and often looks like new - it is inside that changes have taken place - if in doubt change and go the Dayco. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #538041 Wed Oct 11 2017 1:47am
nebc100
Thanks for the info.
I have changed tge belt, but with a contitech belt (my experience with contitech is that their quality is better than Dayco)
The belt that came off only had the Dayco label (no LR label).
Do you think it had been replaced?
Post #538042 Wed Oct 11 2017 4:56am
