![]() | Home > General > Front end vibration |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
With it being under aceleration it could be either a diff or driveshaft problem. |
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
Ok ? Could anyone with this experience elaborate what the problem may be , appreciate all thoughts thank you . |
If I have a problem with either front diff or driveshaft what would it cost to replace / fix either just to give me an idea . The problem seems to be getting more noticeable but doesn't happen if I accelerate on a straight, just when I boot it from coming off a round about. Thanks |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9068 ![]() ![]() ![]() |
Have you had a 4 wheel alignment check done? Incorrect alignment can cause this. Also check tyre pressures. I've found that pressure imbalance across the axle can cause vibrations. Slightly low pressure will also cause it. 2012 SDV6 - it's missing a couple of cylinders
Hi yes had a full wheel alignment carried out when I had front lower wishbones replaced earlier this year . Also tyre pressures Are spot on . I'm trying rack my brains to remember if I had this vibration before I had the wishbones done back in February and to be honest I don't think I did 🤔 Certainly not as noticeable as it is now .... I wondered if It might be the front ARB bushing as it is more noticeable when accerlating off a bend .... at a lost as to what it could be |
How many miles on the vehicle? 2012 SDV6 - it's missing a couple of cylinders
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
It doesn’t sound like th3 same problem I had but might be worth a read of this so that you can rule it out.
Hi , it's just hit the 100 thousand this week . It's a 2008 tdv8 |
Hi Eaters , yes had front to rear swap because of the wear on the fronts but this vibration issue was present before I had that done and both front wheels were rebalanced . I'm considering having the front diff oil inspected now just to see condition of the oil . There's no noise as described in your post . Thanks |
Hi Alfie
On the official LR Service sheets and agreement, changing wheels around is part of all standard service A & B.
Passed MOT today without any issue . Having consulted a local Indy it seems highly likely I have a worn driveshaft ! Which was advised in an earlier reply to my post . Very grateful to all that replied with help I will keep you informed how I go on as I will now have the driveshaft replaced |
jenko2005 Member Since: 29 Jul 2014 Location: Rhoose Posts: 142 ![]() ![]() ![]() |
mines just gone in with a similar problem 61 plate 27,000 miles 3.0 tdv6 happens around 1000-1500 rpm turning into junctions and going around roundabouts been told its 1 of 4 things glad ive got a LR warranty however starstone cardiff been unavailable to diagnose it for the last 8 months or more gone back to where i bought it from
Going in for propshaft fix tomorrow ( centre bearing rubber split possibly damaged centre bearing) my local Indy specialist is replacing centre bearing. Hopefully this will fix the vibration I experience when coming of roundabouts and booting it !! Somehow I doubt it will cuz I suspect it's the torque converter but will let you know this time tomorrow 🤞 |
