Home > Maintenance & Modifications > Rusty Wheel Nuts
Evo5man
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Rusty Wheel Nuts
Hi everyone,
I have received some really good advice and technical assistance with my RRS on this forum so I decided that it was about time that I contributed to the forum. This is my first DIY guide, so please be kind with your comments Thumbs Up
Today I noticed some corrosion sitting in the alloy wheel nut recesses and decided to investigate.
Here is what it looked like
And here with the nut removed
The corrosion is coming from the steel washers and nuts
So I wire brushed the corrosion and then finished off with wire wool
Also cleaned the corrosion from the alloy wheel nut recess and from the nut top face with T cut
Liberally applied copper grease to the steel washer and nut
Refitted the five nuts and job done, hopefully no more corrosion
I hope that this will help other Thumbs Up
Steve
Post #537103 Tue Oct 03 2017 4:53pm
I think the advise is not to put that much grease on as you don't want the thing to become loose.
People also have a problem with the nut part rusting and swelling and then unable to get (the correct sized) socket on.
Post #537107 Tue Oct 03 2017 5:26pm
Cymruambyth
Wales
Looks much better Thumbs Up Steve.
Post #537111 Tue Oct 03 2017 5:43pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
I’ve
Recently Had the swollen nuts issue Razz When I took it in for a service they said I had 9 swollen nuts Big Cry since replacing I have noticed a slight wheel vibration I had has now disappeared completely which has saved a trip to my tyre guy Thumbs Up
Must admit though I don’t not ever put the copper grease on the threaded bit
Post #537113 Tue Oct 03 2017 6:21pm
DrRob
See this thread for swollen nuts
http://www.disco4.com/forum/topic161797.html
I swapped mine out after finding a few swollen ones Censored Visitor from fullfatrr.com
Post #537123 Tue Oct 03 2017 6:40pm
Re: I’ve
No reason not to put small amount on threads, have been doing it for year's on all sorts of vehicles and never had any issues with loose wheels or seized/corroded nut's. I always use a torque wrench though. Thumbs Up
Post #537176 Tue Oct 03 2017 9:54pm
Evo5man
I seem to have stirred up a discussion on the use of copper grease, which was not my intention!
I am with you Col, a small amount of copper grease on a bolt thread and the bolt tightened to the correct torque has always been my philosophy Thumbs Up
I was taught that any moving parts like bearings that needs lubrication should have standard multi-purpose grease applied and anything that is static like a bolt thread apply a small amount of copper grease to prevent corrosion and seizing. Always using a torque wrench of course to ensure the correct torque when tightening.
Steve
Post #537194 Tue Oct 03 2017 11:06pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Re: I’ve
Do you adjust your torque setting for wet thread, the book value is probably for a clean dry thread... Twisted Evil 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #537201 Wed Oct 04 2017 4:35am
Nope, as L/R don't specify lubricated or not just torque them up to required torque and that's it, as I said never had a issue it 35+ years so happy with that, although admittedly I believe there is a formula to calculate variations but you need to know whether the bolts/nut's are plated i.e Zinc, Phosphate, Cadmium etc. as well.
Post #537202 Wed Oct 04 2017 5:58am
insiorc
I used to have a copy of a chart listing all the torque value adjustments, but will admit I also never use it (no idea where it is now either). From memory it went as far as different lubrication value's in oils, like thin oil, thick oil, grease etc. I was hoping the little devil after it might hint at a bit of sarcasm...
I feel chuffed with myself when I actually use a torque wrench rather than the 'how hard to jump on the ratchet lever' method Wink 13MY Range Rover Sport Autobiography SDV6 - mine
Post #537204 Wed Oct 04 2017 7:33am
Twisted Evil Yeah did actually guess that, never really worded my response very well, bit to serious at times these days might well be a age thing. Thumbs Up
Post #537206 Wed Oct 04 2017 7:43am
