![]() | Home > Maintenance & Modifications > Rusty Wheel Nuts |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 ![]() ![]() ![]() |
Hi everyone,
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Looks much better |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
Recently Had the swollen nuts issue |
See this thread for swollen nuts
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5080 ![]() ![]() ![]() |
No reason not to put small amount on threads, have been doing it for year's on all sorts of vehicles and never had any issues with loose wheels or seized/corroded nut's. I always use a torque wrench though. ![]() Cheers Col |
I seem to have stirred up a discussion on the use of copper grease, which was not my intention!
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Do you adjust your torque setting for wet thread, the book value is probably for a clean dry thread... ![]() 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Nope, as L/R don't specify lubricated or not just torque them up to required torque and that's it, as I said never had a issue it 35+ years so happy with that, although admittedly I believe there is a formula to calculate variations but you need to know whether the bolts/nut's are plated i.e Zinc, Phosphate, Cadmium etc. as well.
I used to have a copy of a chart listing all the torque value adjustments, but will admit I also never use it (no idea where it is now either). From memory it went as far as different lubrication value's in oils, like thin oil, thick oil, grease etc. I was hoping the little devil after it might hint at a bit of sarcasm...
