![]() | Home > General > Engine top end strip down |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5062 ![]() ![]() ![]() |
yeap I think the small breathers are on an 8mm bolt. |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Got that damn bracket off the back of the RH side eventually, what a |
That was quick.
Yes after doing the LH side any other job was going to be quicker. |
I'm setting up the cam timing just now on the RH side and noticing that the inside smaller cam (can't remember if this is the inlet or exhaust cam)... should sit in place and lobes not touch any of the lifters?
Don't worry. Nothing wrong.
Superb!!! PHEW... was hoping you were going to say that. Thanks again Andy. |
OK, update on my saga is that timing belt is on and then hand cranked a good few times to get the tensioner pulley just right in the small window. Only thing I have noticed is that when I hand crank it round and all the marks line back up after two cycles of the crank the two cam locking pins go in no problem but the flywheel locking pin is a few millimetres out, what I mean is I just need to turn the crank (with top cam locking pins still in) round a fraction to get the flywheel locking pin in place.
I wouldn't worry. |
Good... cheers Andy, I just like to check these things as I encounter them. |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 ![]() ![]() ![]() |
On and on like Atiston! RRS (MY13) Santorini Black SDV6 HSE luxuary
Got it started |
Wondered how u were going.
The easiest way to get air out of the suspension is take it to a Range Rover specialist? RRS (MY13) Santorini Black SDV6 HSE luxuary
