Home > Technical > Limp mode..... restarted.... all fine now.. hmmm
Jampot1979
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Ive only had my tdv8 a week. just done a 400 mile trip in it. Well on the way home while travelling at 50ish i went to overtake and put my foot down when a engine fault came up on display and it went into limp mode.
I pulled over, turned it off, waited a couple of minutes then restarted. All was fine for the rest of the journey. I even booted it etc trying to see if it would do it again. no smoke, turbos kicking in, pulling well!
There was a message that came up on the display the last few times i started the car, but now thats even gone. no warnings etc now.
i have a 200mile journey to do this weekend..... hope its ok.
Anyone else had this issue?
Post #536719 Fri Sep 29 2017 8:59pm
Disco_Mikey
Top turbo hoses, blocked fuel filter, sticky turbo actuators are all common issues Thumbs Up
Post #536721 Fri Sep 29 2017 9:24pm
Jampot1979
Thanks for the reply.... The fault message has gone on the initial turning the keys to start. I have a 200 mile round trip to do tomorrow so fingers crossed it does it.
I had filled the fuel tank to the max for the first time since owning it.... Would that have put extra strain on the fuel filter?
Is there any way to read any fault codes on the display? Or is it a plug in tool thing?
Post #536724 Fri Sep 29 2017 9:39pm
GodivaNige
Pulling the stored fault codes would give you a better idea.
I’ll have a pound on sticky turbo actuator Thumbs Up Wink
The Gap IID BT is the tool of choice at approx £400 (worth every penny) but there are cheaper LR specific code reading tools available.
Post #536728 Fri Sep 29 2017 10:27pm
Jampot1979
Thanks peeps for the replies.
So a sticky turbo actuator is a fix with wd40 ?
Just been reading through this forum and it seems to be the answer for many people.
Like I said, I only purchased the car a week ago, and before that it's sat on a forecourt for at least a month or two.
Post #536738 Sat Sep 30 2017 6:41am
geoffsnook
Take it back to them and ask them to read the codes Thumbs Up
Post #536740 Sat Sep 30 2017 8:27am
Jampot1979
Have taken it back. Codes coming up apparently are showing an air supply issue. Confused
Post #537066 Tue Oct 03 2017 1:50pm
mattmoo138
Hey Jampot
I have exactly the same issue on my 2012 and the dealer also getting air related codes. they change dout the air sensor on bank 1 as it was reading 0 so they guessed it was that, but still doing it. its going back again this weekend. did you manage to get it resolved?
Post #537101 Tue Oct 03 2017 4:29pm
Jampot1979
Had diagnostic done on my TDV8 sport today. Code p023 - boost pressure fault. On further inspection a hairline crack was found on the offside inlet manifold.
So now just waiting for the garage to get back to me with a price for the repair. I gather it's a fiddly job. So will be £££.
Post #538279 Sat Oct 14 2017 8:38pm
mattmoo138
Keep me updated.. mine went in today.. let's see what comes of it..
Post #538284 Sat Oct 14 2017 10:19pm
Tim in Scotland
Jam pot, you have had the car 1 month, if you bought from any sort of dealer then you should have some sort of warranty even if from a non-franchised dealer. Cracked heads don’t happen overnight...... it would be a good idea to have the bits Mikey suggested checked out at the same time, hose failures are common and relatively cheap to fix. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #538293 Sun Oct 15 2017 3:16am
Jampot1979
I have checked all the other bits out which are fine. I do have a warranty (warranty first) so will see if they will cover the inlet manifold.
The inlet manifold is made of plastic. It's has a hairline crack along it.
Had fuel filter changed, actuators checked and all intercooler hoses are fine.
Post #538296 Sun Oct 15 2017 8:22am
Jampot1979
Good news, 'Warranty First' have authorized the repair of my sport. Only 70 quid excess to pay. So it's now booked in for a new inlet manifold.
Really thought the warranty company were going to reject it as the inlet manifold wasn't on the inclusion list.
Thumbs Up Cool Very Happy
Post #538795 Fri Oct 20 2017 2:09pm
Jampot1979
Had the inlet manifold replaced on the driver's side. Seems to have fixed the problem. Fingers crossed I get some trouble free motoring for a while Thumbs Up Bow down
Post #539808 Tue Oct 31 2017 6:24pm
Cymruambyth
Wales
Result Thumbs Up Steve.
Post #539830 Tue Oct 31 2017 9:13pm
