![]() | Home > Technical > Limp mode..... restarted.... all fine now.. hmmm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4505 ![]() ![]() ![]() |
Top turbo hoses, blocked fuel filter, sticky turbo actuators are all common issues |
Jampot1979 Member Since: 23 Jun 2017 Location: Bedfordshire Posts: 145 ![]() ![]() ![]() |
Thanks for the reply.... The fault message has gone on the initial turning the keys to start. I have a 200 mile round trip to do tomorrow so fingers crossed it does it.
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Pulling the stored fault codes would give you a better idea.
Thanks peeps for the replies.
Take it back to them and ask them to read the codes |
Have taken it back. Codes coming up apparently are showing an air supply issue. |
mattmoo138 Member Since: 03 Oct 2017 Location: London Posts: 9 ![]() ![]() ![]() |
Hey Jampot
Had diagnostic done on my TDV8 sport today. Code p023 - boost pressure fault. On further inspection a hairline crack was found on the offside inlet manifold.
Keep me updated.. mine went in today.. let's see what comes of it.. |
Jam pot, you have had the car 1 month, if you bought from any sort of dealer then you should have some sort of warranty even if from a non-franchised dealer. Cracked heads don’t happen overnight...... it would be a good idea to have the bits Mikey suggested checked out at the same time, hose failures are common and relatively cheap to fix. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I have checked all the other bits out which are fine. I do have a warranty (warranty first) so will see if they will cover the inlet manifold.
Good news, 'Warranty First' have authorized the repair of my sport. Only 70 quid excess to pay. So it's now booked in for a new inlet manifold.
Had the inlet manifold replaced on the driver's side. Seems to have fixed the problem. Fingers crossed I get some trouble free motoring for a while |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Result |
