Home > General > side steps
murphy
United Kingdom 2006 Range Rover Sport TDV6 HSE Arctic Frost
side steps
Hi. I have been looking at side steps for my RRS found these on ebay are they any good or are they rubbish, has anyone any advice http://www.ebay.co.uk/itm/New-OEM-Spec-Sid...rksid=p206
Post #536633 Thu Sep 28 2017 2:12pm
Johnski
Can't comment on that model which is very cheap around £500+ less than genuine.
One thing to watch very carefully is that none seem to be made as well as genuine, and don't hold the weight LR genuine do at 21stone plus. Most copies are up to 13-15 stone max, some sellers I wrote to had no idea, some made from Steel and alloy, others just alloy, so be careful of what you are buying and the fit of them of course. John
Post #536634 Thu Sep 28 2017 2:19pm
Tyrefitter
To be honest ive fiited aftermarket steps off ebay with no problems,,just make sure you get them with the plastic covers which they have,if not they are a pig tomark out & cut.It takes about 30 minutes a side to fit those & that's laid on the floor.Ive just ordered a set for my 2014 SC that I pic up tomorrow,,they were £174 its a big saving to what dealers ask for them.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #536637 Thu Sep 28 2017 2:35pm
murphy
Thank you Johnski, and Tyrefitter do you mean the ones I linked to have the plastic covers, I don't mind spending a a bit more if you could tell me which ones as I do not know very much about them
Post #536638 Thu Sep 28 2017 2:50pm
Tyrefitter
Hi Murphy,,the ones you have linked have the plastic sill covers pre-cut which are easy to fit,,you can buy some without them & cut your own but its a nightmare marking them out & it takes 3 times aslong to fit.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #536639 Thu Sep 28 2017 2:54pm
murphy
Thank's Andy
I think I will go ahead and order them
Post #536642 Thu Sep 28 2017 3:32pm
jason-nike
Thanks everyone for the info.
I've been looking at these too, will now order a set
Post #536685 Fri Sep 29 2017 10:30am
Johnski
Please if you could post about quality/finish etc once fitted so this can be passed onto others when asked in future.
Not everyone is as heavy as me so often don't require genuine. Whistle Embarassed Wink John
Post #536697 Fri Sep 29 2017 2:03pm
m3virus
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
I bought a set of steps from them guys quality finish is great look identical to genuine,
I weigh 16 stones and have not had any problems in the last 3 years.
Just make sure you put loads of copper grease on the bolts when fitting this will stop any rust setting in on bolts👍 Current 55 reg 2.7tdvs with Hst extras
Post #536698 Fri Sep 29 2017 2:37pm
Eaters
I bought a set off eBay for around the £160 mark. Easy to fit and good enough for me
 Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #536732 Fri Sep 29 2017 11:01pm
When I did mine I actually changed the bolts for stainless steel one's as well as copper slip. Thumbs Up
Post #536734 Fri Sep 29 2017 11:07pm
Evo5man
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
I purchased a set of side steps off eBay and I was very pleased with the quality. Fitting is a relatively easy DIY job just put the suspension to its highest setting and there is enough ground clearance to fit the steps without jacking up the car. I too put plenty of grease on the bolts and some corrosion protection on the brackets.
One piece of fitting advice, after fitting my brackets and the plastic sill covers the bracket step support legs did not fully align with the steps. So eventually I had to remove the plastic sill covers, loosen the bracket bolts and temporarily fit the steps on the brackets before retightening the brackets bolts. I then removed the steps, refitted the plastic trims and then permanently fitted the steps.
My advice would be to fit the brackets and bolts finger tight, temporarily fit the steps to the brackets to align the brackets. Then tighten the bracket bolts with the steps still attached to the brackets. Then remove the steps, fit the plastic trims and then refit the steps.
Hope this helps.
Steve Thumbs Up
Post #537000 Mon Oct 02 2017 11:06pm
Tyrefitter
Ive just ordered a set for mine £137.50 by the time Ive claimed the dreaded vat back,,I’ll let you know how the quality is & how easy to fit as I’ll be fitting them probably Friday..But I have got ramps & lift to make it easier.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #537005 Tue Oct 03 2017 6:35am
Eaters
Best of luck for Friday Andy.
One thing I wish I had done with mine was to protect the aluminium edge strip somehow. Obviously its the front edge of that strip gets a real battering whilst you are driving along and, on my steps, it has marked up quite badly. There may be no solution but if you know of anything (perhaps even just wax polish) that would help protect it, that would be worth investing a bit of time in. I guess ideally some sort of lacquer might be a solution but I'm out of my area of expertise here. Perhaps my steps were inferior and others come with a better finish - I don't know. But logic says that whatever you can do to protect that front edge would be a good move. Mine is already marked so that my only real solution now is to remove them and repaint the edge.
 Robin
Gone:
MGZTT 190 2.5
Post #537011 Tue Oct 03 2017 8:31am
Tyrefitter
Ive got some Gtechiq C5 left over so I might just put some on the alloy part of them.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #537015 Tue Oct 03 2017 8:46am
