![]() | Home > General > side steps |
murphy Member Since: 04 Sep 2017 Location: London Posts: 22 ![]() ![]() ![]() |
Hi. I have been looking at side steps for my RRS found these on ebay are they any good or are they rubbish, has anyone any advice http://www.ebay.co.uk/itm/New-OEM-Spec-Sid...rksid=p206 |
Can't comment on that model which is very cheap around £500+ less than genuine.
Thank you Johnski, and Tyrefitter do you mean the ones I linked to have the plastic covers, I don't mind spending a a bit more if you could tell me which ones as I do not know very much about them |
Hi Murphy,,the ones you have linked have the plastic sill covers pre-cut which are easy to fit,,you can buy some without them & cut your own but its a nightmare marking them out & it takes 3 times aslong to fit.
Thank's Andy
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
Thanks everyone for the info.
Please if you could post about quality/finish etc once fitted so this can be passed onto others when asked in future.
m3virus Member Since: 18 Sep 2013 Location: birmingham Posts: 36 ![]() ![]() ![]() |
I bought a set of steps from them guys quality finish is great look identical to genuine,
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
I bought a set off eBay for around the £160 mark. Easy to fit and good enough for me
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5153 ![]() ![]() ![]() |
When I did mine I actually changed the bolts for stainless steel one's as well as copper slip. ![]() Cheers Col |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 ![]() ![]() ![]() |
I purchased a set of side steps off eBay and I was very pleased with the quality. Fitting is a relatively easy DIY job just put the suspension to its highest setting and there is enough ground clearance to fit the steps without jacking up the car. I too put plenty of grease on the bolts and some corrosion protection on the brackets.
Ive just ordered a set for mine £137.50 by the time Ive claimed the dreaded vat back,,I’ll let you know how the quality is & how easy to fit as I’ll be fitting them probably Friday..But I have got ramps & lift to make it easier.
Best of luck for Friday Andy.
Ive got some Gtechiq C5 left over so I might just put some on the alloy part of them.
