Home > General > Rear interior lights
Page 2 of 3 <123>
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
SRE wrote:
Guess it's all down to cost, add 2 wires etc at circa £0.40 each into the harness X the annual prodution of RR Sports, quite a big on cost.
yes actually this does explain why every other car (with rear lights) in existence has the feature and why they are all so bloody expensive!!! Mr. Green ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #326929 Thu Jan 05 2012 9:50am
simon1233
Options are simple, either put up with the back of the car being dark or invest 90 minutes of your life and approx £2 and do the mod so that you/your kids can actually see what they are doing with their seat belts etc when they get into the car on these dark winter evenings or buy either a FFRR or Disco as both these cars have rear overhead courtesy lights...
Lack of overhead courtesy lights in the rear of the RRS was/is a massive oversight by LR.
Post #326936 Thu Jan 05 2012 10:30am
rrsboy
it is quite shameful ============
Post #326985 Thu Jan 05 2012 3:51pm
Ashie50
England 2007 Range Rover Sport TDV6 HSE Rimini Red
Easy fix , I've tried getting prices from garages first but they just seemed to pull prices out the air . A very easy mod thanks for sharing Thumbs Up
Post #489280 Sun Feb 28 2016 11:33am
EC Rover
United States 2009 Range Rover Sport 4.4 V8 HSE Alaska White
Simon1233, Did you use 2 diodes in this mod? I'm trying to convert the lights in my 2009 RRS and all this information is extremely helpful but although I do not have the experience of running wires I will still attempt to do this. I understand that you are running 1 wire down from each light (left & right) and then joining the other ends to the gray side of the diode and then splicing the other end into the wire from the cargo area light, but where is the other diode?
I also read the original post by Alan but could not see his pictures. I think tying it into the rear cargo light seems easier.
Post #535902 Tue Sep 19 2017 6:13pm
You use 1 diode for the left light
1 diode for the right light.
May as well put the diodes by the trunk light.
so they are together and have easy access.
I'm sure there are 2 other posts about this
http://www.rrsport.co.uk/forum/topic20566.html?highlight=diode
http://www.rrsport.co.uk/forum/topic44340.html?highlight=diode
Post #535909 Tue Sep 19 2017 7:34pm
EC Rover
Thanks AndyK.
Just so I'm understanding this correctly it's:
A) Reverse the configuration of the black and green/white wires in each courtesy lamps
B) splice a new wire to the Green/White wire from each of the courtesy lamps
C) run the two new wires down towards the cargo area lamp
D) attach a diode to the other end of each new wire
E) splice the other end of the 2 diodes together and attach another piece of wire to that connection
F) splice that wire to the hot wire running from the cargo area lamp
Did I leave anything out?
Post #535915 Tue Sep 19 2017 8:42pm
I think you better re read and I'll check when I get a moment, but.
I think its actually:
Think B & F maybe wrong.
B) The wire goes directly to the bulb holder itself, thus bypassing the switch in the light
Post #535917 Tue Sep 19 2017 8:49pm
EC Rover
Ok, I have to look at that again then concerning B but what is wrong with F?
Post #535919 Tue Sep 19 2017 9:23pm
Just checked,
You are correct.
Nothing wrong with F.
My mistake. Sorry
Post #535921 Tue Sep 19 2017 9:31pm
duplicate
Post #535922 Tue Sep 19 2017 9:31pm
EC Rover
Thanks for your help Andy. I will let you know how it turns out. I may not get to it as quickly as I'd like but I will definitely tell you after it's done.
Post #535924 Tue Sep 19 2017 9:36pm
you need to ensure the diode is fitted the correct way round.
else it won't work correctly
Post #535977 Wed Sep 20 2017 12:12pm
simon1233
Pictures are in my gallery, links below
Not been on here for a while and using an ipad on a train, so hoping that these links work
Simon
Post #536112 Thu Sep 21 2017 7:31pm
Bill Portland
Great guide Simon! Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #536147 Fri Sep 22 2017 7:24am
Page 2 of 3 <123>
