Home > General > Any one in Southampton
Bulletsaints
England 2005 Range Rover Sport TDV6 SE Java Black
Hi I was wondering if there's anyone in Southampton that can plug in my rrs 2005 as I've had special program not available on the dash since I've owned it. Basically the knob for changing terrain etc doesn't light up or do anything although when you first turn ignition on the left hand display under rev counter lights up then goes out, air suspension all works fine.
Can anyone help please
Post #535840 Mon Sep 18 2017 10:55pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
I'm Horndean side of Waterlooville if that helps. I have a NT510 multi system scanner. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #535854 Tue Sep 19 2017 6:00am
DrRob
www.west4x4.co.uk * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #535870 Tue Sep 19 2017 9:56am
Bulletsaints
rob,do you no a rough cost of this and if there open saturdays at all ?
Post #535872 Tue Sep 19 2017 10:00am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Have you tried using the HDC button? Does that work? What about the Hi/Low selctor or suspension height selector? Do any of these work?
If not perhaps the plug is loose or not connected, but, I'm surprised you don't get any error messages if this is the case.
If the above holds true you can check yourself. Make sure the engine is off, etc. etc. Then remove the gear knob with a firm upward pull. Then carefully prize the terrain response fascia up (its held on with 4 or 6 panel clips and see if the large plug is inserted correctly'into the underside ofthe terrain resonse.
If yes then either the terrain response unit may be duff or there's a problem somewhere in the loom that'll need diagnosing professionally.
Hope that helps
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #535878 Tue Sep 19 2017 11:36am
DrRob
I don't I'm afraid but they are the local experts Thumbs Up
Give them a call.... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #535883 Tue Sep 19 2017 12:20pm
Bulletsaints
Thanks rob
Guyzer73........... the lights on the knob you twist and the green screen under rev counter light up when ignition is first turned on but then go out, the air suspension all works fine up and down and so do the hi and low. not sure what the hdc button is though lol. i brought it like this and have never bothered me as not using it for off road, but now im selling it id like to try and sort it
Post #535884 Tue Sep 19 2017 12:57pm
DrRob
Yes, any buyer who is clued up will want to see it working Thumbs Up
Mark West will sort it Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #535887 Tue Sep 19 2017 2:34pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
Bullet, I can recommend Sean at S&C ... which is Netley so near to you I would guess..
www.sandcmotors.co.uk Carl
Post #536736 Fri Sep 29 2017 11:11pm
DrRob
I've heard of S&C but never had any feedback from people who use them....how good are they? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #536743 Sat Sep 30 2017 8:56am
V8SC
I've used S&C several times following a recommendation from a family friend who has used them for years for Jaguar and Landrover.... Thumbs Up Carl
Post #536874 Sun Oct 01 2017 9:37pm
