Home > Faults & Fixes > Remote not working
Plazmapete
Remote not working
Hi all. So after changing both rear brake lights I have noticed my remote central locking is playing up. I know these vehicles are fussy. Do you think they could be linked ??
I did remove the car battery and short the terminals to reset. But still the same.sometimes it will lock apart from the drivers door unless I press it twice. The tailgate button looks to be working fine. Thanks in advance. New alternator.
Gearbox flush.
Post #533841 Sat Aug 26 2017 5:49am
Socast
Quickest and easiest way to see if your new brake bulbs are causing the issue would be to take them out and see if you still have the same issue. Thumbs Up
Post #534003 Tue Aug 29 2017 9:04am
Oldandconfused
Did you use genuine LR brake bulbs? The reason I ask is that I understand these cars are very sensitive to them, and some can cause all sorts of electrical issues. I have always used gen LR bulbs for that reason, they are after all relatively cheap.
Of course, it may have nothing to do the bulbs at all. Good luck.
Post #534014 Tue Aug 29 2017 12:47pm
Plazmapete
No. They were brake lights from a set i got from aldi. Haven't used the car for 3 days due to working over the weekend. Today it seems to be working fine. Will have to get some genuine bulbs to replace the ones from my set just in case. Thanks. New alternator.
Gearbox flush.
Post #534025 Tue Aug 29 2017 3:00pm
Oldandconfused
It's been a while since I bought some, my old D3 tended not to blow them, and I seem to remember they came in packs of 2.
Let's hope it was a one off.
Post #534028 Tue Aug 29 2017 4:27pm
Plazmapete
It worked fine yesterday. Today it's playing up. Will get a couple of genuine bulbs. See if that cures it. New alternator.
Gearbox flush.
Post #534078 Wed Aug 30 2017 10:02am
minty77
United Kingdom 2005 Range Rover Sport TDV6 S Alaska White
These guys fixed my fobs for me, Did a great job and they are still working now, Give them a try Thumbs Up
www.keys2u.co.uk
Post #534466 Sun Sep 03 2017 4:46pm
Plazmapete
I've tried to re sync the keys. Followed the procedure. Seems to work. Then if I lock and unlock the doors a couple of times it works fine. But When I come to lock the car the horn beeps at me. I have to start the car then turn it off to lock the car. New alternator.
Gearbox flush.
Post #534527 Mon Sep 04 2017 5:19pm
Plazmapete
Took the circuit board out of the key to ckeck the voltage. Getting 3 volts. I can open and close the car from 15 metres away no trouble. Its when the board is in the case im having trouble. Any thoughts?? New alternator.
Gearbox flush.
Post #535647 Sun Sep 17 2017 11:35am
adameverett
Dry joint on the battery? I had a similar issue with a key intermittently would not lock/unlock. Replaced the Battery problem went away. Just a guess but key is loosing power, and you are resetting it when you reinsert/restart. I know that I had a bad contact as I use to tap the key on the ground it stated working again.
Post #535693 Sun Sep 17 2017 8:41pm
Plazmapete
UPDATE. THINK ITS SORTED.
noticed one of my number plate bulbs had gone. Changed the bulb and now both keys seam to be working again. What are the chances of that ??? New alternator.
Gearbox flush.
Post #536315 Sun Sep 24 2017 2:20pm
Plazmapete
It lasted for two weeks then went again. All bulbs are fine. Now it's an intermittent fault. Visit to garage I think. New alternator.
Gearbox flush.
Post #538267 Sat Oct 14 2017 1:29pm
