![]() | Home > Faults & Fixes > Remote not working |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594
Quickest and easiest way to see if your new brake bulbs are causing the issue would be to take them out and see if you still have the same issue. |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784
Did you use genuine LR brake bulbs? The reason I ask is that I understand these cars are very sensitive to them, and some can cause all sorts of electrical issues. I have always used gen LR bulbs for that reason, they are after all relatively cheap.
| Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118
No. They were brake lights from a set i got from aldi. Haven't used the car for 3 days due to working over the weekend. Today it seems to be working fine. Will have to get some genuine bulbs to replace the ones from my set just in case. Thanks. New alternator.
It's been a while since I bought some, my old D3 tended not to blow them, and I seem to remember they came in packs of 2.
It worked fine yesterday. Today it's playing up. Will get a couple of genuine bulbs. See if that cures it. New alternator.
| minty77 Member Since: 05 Oct 2016 Location: Lancashire Posts: 14
These guys fixed my fobs for me, Did a great job and they are still working now, Give them a try |
I've tried to re sync the keys. Followed the procedure. Seems to work. Then if I lock and unlock the doors a couple of times it works fine. But When I come to lock the car the horn beeps at me. I have to start the car then turn it off to lock the car. New alternator.
Took the circuit board out of the key to ckeck the voltage. Getting 3 volts. I can open and close the car from 15 metres away no trouble. Its when the board is in the case im having trouble. Any thoughts?? New alternator.
| adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110
Dry joint on the battery? I had a similar issue with a key intermittently would not lock/unlock. Replaced the Battery problem went away. Just a guess but key is loosing power, and you are resetting it when you reinsert/restart. I know that I had a bad contact as I use to tap the key on the ground it stated working again. |
UPDATE. THINK ITS SORTED.
It lasted for two weeks then went again. All bulbs are fine. Now it's an intermittent fault. Visit to garage I think. New alternator.
| All times are GMT |
