![]() | Home > Technical > TDV8 loud whistling on boost |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
Cracked inlet manifold. Got any fault codes?
Sporticus Member Since: 12 Dec 2016 Location: Scotland Posts: 12 ![]() ![]() |
No fault codes or warning lights.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4528 ![]() ![]() ![]() |
Broken exhaust manifold stud, and subsequent warped manifold... |
How much am I looking at to fix?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
Four figures. Manifolds are £600 a piece and it's a body off job to do them. 2012 SDV6 - it's missing a couple of cylinders
I read the manifolds can be skimmed though so this would bring down the cost?
And can the broken studs be visually spotted first before the body is removed |
Last manifold I has skimmed was £180 ![]() Can usually be seen before lifting the body, but either way, it's a body off job to extract the broken stud and remove the manifold... |
What sort of bill am I looking at Disco Mikey?
