| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > MOT Fail - Lower Arm Bushes |
| Copilot Member Since: 06 Jan 2014 Location: Sussex Posts: 31      | No idea if this is the norm pal. All I can say is that in nearly four years of ownership, covering 36k, I have had no problem with lower arm bushes (MY10) - I would be peeved at having to replace any part twice in eighteen months though. | ||
|  Thu Sep 07 2017 6:57pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | If they have not been fitted correctly, they can wear out even quicker than you have experienced... | ||
|  Thu Sep 07 2017 6:59pm |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407      | Bad luck on the MOT failure.
|  Thu Sep 07 2017 7:12pm |
| adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110      | thanks guys,  certainly got me questioning previous fitment.  I would be happy with 5 years life but this just seems premature failure to me.  | ||
|  Thu Sep 07 2017 7:18pm |
| Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251      | Isn't somebody selling the poly bush set in the FS section?. | ||
|  Mon Sep 11 2017 7:51am |
| adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110      | cheers bud for the thought  | ||
|  Mon Sep 11 2017 8:38pm |
| sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961      | Sorry to say but I bet the damage has been done. Think it takes a couple of days.   | ||
|  Mon Sep 11 2017 8:49pm |
| squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193      | I fitted poly bushes to the front lower arm's, both bushes (front and rear). They are a bit firmer, but I don't get any squeaking in fact quite pleased with them. | ||
|  Tue Sep 12 2017 5:15am |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784      | It's worth taking the compressor cover off (only 3 bolts if it's the same as aD3) and checking the alloy compressor bracket to see if they have broken it. If they have the compressor will vibrate against the chassis.
|  Tue Sep 12 2017 7:36am |
| Posting Rules
 I just cannot believe the arms have failed in just 18 Months since they were replaced, and probably only covering 12k miles in this time.   I know they are heavy cars and lower arms are prone to fail but 18Months
 ,  I checked they were rears
 ,  I checked they were rears  .   Indy has fitted me some poly bush on the front arms, not sure if its just my imagination but ride does feel stiffer, but then again if the rubbers were worn then new rubbers might have same feeling.   Some people have said they squeak, I don't want to curse it but no squeaks!.
 . Car dropped on the jack about 1 cm.  I shouted the shop manger who went running over and relocated the jack further underneath onto the rails.  Tested the car in the shop seem to lift up and down but still but really not sure if any damage under the box covers.   Tempted to remove the box covers and take a look in the day light.
