![]() | Home > Maintenance & Modifications > MOT Fail - Lower Arm Bushes |
Copilot Member Since: 06 Jan 2014 Location: Sussex Posts: 31 ![]() ![]() ![]() |
No idea if this is the norm pal. All I can say is that in nearly four years of ownership, covering 36k, I have had no problem with lower arm bushes (MY10) - I would be peeved at having to replace any part twice in eighteen months though. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
If they have not been fitted correctly, they can wear out even quicker than you have experienced... |
Bad luck on the MOT failure.
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 ![]() ![]() ![]() |
thanks guys, certainly got me questioning previous fitment. I would be happy with 5 years life but this just seems premature failure to me. |
Isn't somebody selling the poly bush set in the FS section?. |
cheers bud for the thought |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
Sorry to say but I bet the damage has been done. Think it takes a couple of days. |
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193 ![]() ![]() ![]() |
I fitted poly bushes to the front lower arm's, both bushes (front and rear). They are a bit firmer, but I don't get any squeaking in fact quite pleased with them. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
It's worth taking the compressor cover off (only 3 bolts if it's the same as aD3) and checking the alloy compressor bracket to see if they have broken it. If they have the compressor will vibrate against the chassis.
