![]() | Home > Faults & Fixes > Another Air con question |
Godivanige i will certainly try and do that over the next few days and post on here the inefficient compressor is sounding right at the moment :thumbsup |
Right here we go then
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Yep, still the same conclusion, either slightly low on refrigerant or the compressor is worn
I will empty the system first i think and see how much is in there with my mates machine at least then i should be able to eliminate either low refrigerant or faulty compressor thanks for all the advice |
Well an update down to garage today and took out 220 grams so a leak is there ,So off with the front end of the car (what a bitch compared to a disco 3 with those extra rads) so got it off and wtf half the rad is missing cant believe it was holding any pressure so replaced and refilled pressure up around the 10 bar mark and evap temp down quickly to 3.5 so thanks for the help everyone and here's hopping |
Thanks but at £105 all in i cant complain can i |
Once again thanks for the tips |
Hocks172 Member Since: 01 Dec 2016 Location: Brighton Posts: 84 ![]() ![]() |
Just thought i'd put an update on my Aircon issues, beware long story.
wow it is nice to know they get sorted but can take some time |
Yeah perseverance is the word! Oh and money👍🏻 RRS Autobiography SDV6 19
Yep and best the pockets are deep |
johnsporttdv8 Member Since: 02 Nov 2014 Location: Cambridgeshire Posts: 16 ![]() ![]() ![]() |
Read this complete thread and learned a great deal.
I think you've pretty much solved your own problem here John, the compressor is dying as it can't efficiently compress the refrigerant at low speed. Given that its noisy as well confirms it is on it's last legs.
