Home > Maintenance & Modifications > 2006 rrs se faults. 2.7 diesel
Donegalrangerover
Ireland
Hi all,
My first of many questions on the rrs. Bought her a few days ago and she's laid down now after valeting.
5 warning lights on the dash. I'll try and attach a photo. No faults before it got valeted.
When going around corners it feels very "boaty" on the back end. Every now and again there's the sound of an air release.
What do the learned members recommend ? Aside from burning it out......
Post #534804 Fri Sep 08 2017 7:35pm
Charge the battery
Post #534805 Fri Sep 08 2017 7:38pm
Donegalrangerover
Ireland
Hi Andy,
I put a new battery it it when attempting to clear the faults.
Post #534807 Fri Sep 08 2017 7:41pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
They haven't steam cleaned or jet washed the engine during the valeting have they?
Post #534834 Fri Sep 08 2017 10:32pm
Donegalrangerover
Ireland
Not steam cleaned but maybe jet washed.
Post #534835 Fri Sep 08 2017 10:43pm
phillh
If it were my car, bearing in mind it was fine before valeting, I would check for water ingress under the bonnet. That would mean disconnecting every electrical connection I can find, drying it, applying wd40 or similar and seeing if that makes any difference. Have you had faults read yet?
Post #534839 Fri Sep 08 2017 11:12pm
there are some ecu's behind the battery that don't like getting wet.
requires battery removal.
Post #534855 Sat Sep 09 2017 10:20am
Donegalrangerover
Ireland
Update from today. Had it on the computer and theres no communication with the transmission control module.
Anyone had this before????
Post #534885 Sat Sep 09 2017 8:55pm
phillh
This thread may be of help to you:-
http://www.rrsport.co.uk/forum/topic48575....rol+module
Post #534886 Sat Sep 09 2017 9:11pm
Sharpy1980
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
As someone mentioned above there are ecus behind the battery and I'm sure the transmission ecu is one of them. Clickadeeclick
Post #534887 Sat Sep 09 2017 9:32pm
Donegalrangerover
Ireland
Thank you everyone for your assistance.
Removed, cleaned the ecu and plugs behind the battery. All fault lights off.
Post #534937 Sun Sep 10 2017 6:46pm
You have been lucky
Hope it lasts.
Post #534940 Sun Sep 10 2017 6:56pm
phillh
Glad you are sorted, enjoy the car now.
Post #534952 Sun Sep 10 2017 8:41pm
