![]() | Home > Maintenance & Modifications > 2006 rrs se faults. 2.7 diesel |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
Charge the battery |
| Donegalrangerover Member Since: 05 Sep 2017 Location: Donegal Posts: 8
Hi Andy,
| phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198
They haven't steam cleaned or jet washed the engine during the valeting have they? |
If it were my car, bearing in mind it was fine before valeting, I would check for water ingress under the bonnet. That would mean disconnecting every electrical connection I can find, drying it, applying wd40 or similar and seeing if that makes any difference. Have you had faults read yet? |
there are some ecu's behind the battery that don't like getting wet.
Update from today. Had it on the computer and theres no communication with the transmission control module.
This thread may be of help to you:-
| Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98
As someone mentioned above there are ecus behind the battery and I'm sure the transmission ecu is one of them. Clickadeeclick |
Thank you everyone for your assistance.
You have been lucky
Glad you are sorted, enjoy the car now. |
| All times are GMT |
