Home > General > Engine top end strip down
Page 7 of 13 <123 ... 678 ... 111213>
DerrekL
Disco_Mikey wrote:
With a cylinder head skimmed, it moves the valves closer to the pistons. A thicker gasket accounts for this removal of material
OK, this is where things get interesting... Disco_Mikey I won't be getting the head skimmed, does this change things?
I will probably be putting a 2nd hand head on though. Would this require me to measure (what and how) to determine the thickness of new gasket I require? I do have access to some precision engineering tools that should aid in this measuring process? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533577 Wed Aug 23 2017 9:05am
DerrekL
Would this be the way to go for head gasket choice?
Does the identification column relate to how many notches the gasket has? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533660 Thu Aug 24 2017 10:21am
Disco_Mikey
Yes. The head surface must be absolutely flat for the gasket to seal correctly, a skim does this perfectly...
You will need to measure your current head, compare that with your replacement head, and measure the piston heights to identify the correct gasket Thumbs Up
Then post up your reg number, or the last 6 digits of your chassis number
Post #533662 Thu Aug 24 2017 10:42am
DerrekL
The 'Gasket Selection Table' I just posted doesn't mention anything about measuring the heads, it only mentions more the piston protrusion and to go with that measurement to decide the gasket option, is what I was thinking, is that not true?
What do you mean by measure the original head and replacement head. What points of the head do I measure? and where do those measurements fit into the equation?
I thought it was just the bottom end pistons that I would have to hand crank until they reached the top of their/each cycle then measure the piston protrusion to determine gasket thickness. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533666 Thu Aug 24 2017 11:25am
Disco_Mikey
The thicker gasket compensates the amount taken off by skimming Thumbs Up
Post #533692 Thu Aug 24 2017 3:52pm
DerrekL
yes I get that, no probs in working that one out Thumbs Up but as no skimming involved here just replacement head put straight on. What you said previously was measure the head and replacement head, but at what points are they measured? RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533693 Thu Aug 24 2017 3:55pm
DerrekL
...DM I'm still not sure what I should be measuring on the head, mating face of head to top of valve maybe?
Probably time to get a replacement head or two. Things to note when buying a replacement head?
The only number I see on my LH head is PM 4R8Q-6C064
Does this have to be stamped on the heads I buy or could this be a different number? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533728 Thu Aug 24 2017 8:37pm
I put a jag head on mine so I guess it's not that fussy lol
Post #533746 Thu Aug 24 2017 10:22pm
DerrekL
Cheers Andy, yes know what you mean Very Happy but since I'm going to all this effort thought I would try and find out what other folks have done in a similar situation. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533762 Fri Aug 25 2017 8:21am
Disco_Mikey
If you are going to all this effort, is it not worth doing the job correctly?
A light skim at the very least to ensure a perfectly flat sealing surface...
Post #533764 Fri Aug 25 2017 9:01am
DerrekL
Yes that would indeed be an option, remembering I have never taken on this scale of job before and only taking advice and using own savvy into the mix and the general consensus was that peeps who have done this job before have opted not to skim head.
This said Mikey I do appreciate all the advice given and would be grateful if you could recommend engineering shops you or anyone else may have used before (preferably up here in Jock land) so I could investigate further if I decide to go down the skim head route. Cheers... Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533768 Fri Aug 25 2017 9:29am
DerrekL
Anyone used or heard of this make:
Victor Reinz
...looking to buy head gasket(s) and head bolts.
Or any other recommendations? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533777 Fri Aug 25 2017 10:55am
For a DIYer They would need to
Find a place to do it and engage with them
Strip the valves out the head and glow plugs and anything else
Wait a week for the work to be done. Pay them money
Clean the head off twice; before and swraf off after
Victor Reinz as a very well know brand for gaskets, and OEM for some manufactures
I paid £100 for a top end gasket set and headgaskets.
Probably need to add £10 to get head gaskets seperate.
For headbolts I purchased from Advance Factors and Island 4x4 britpart?
Post #533783 Fri Aug 25 2017 11:40am
DerrekL
Thanks for parts advice Andy. I should be ordering some of what I need over the weekend. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #533784 Fri Aug 25 2017 11:44am
you probably want to download an engine manual.
e.g citroen, jaguar or landrover
to give you the headbolt tightening sequence, torque and angle tightening. (the later I did in two stages for ease)
Post #533785 Fri Aug 25 2017 11:47am
