Home > General > Hope he's wrong
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Hope he's wrong
Hello all any thoughts appreciated
Working merrily away when I get a call off the wife
I'm broke down all the lights are flashing
On the dash board tried to start it won't start
I asked what's happened
I was only doing 20 over some speed bumps
and it just lost power and it stopped
Ok call green flag out lowloader to local
Indie I use ( sport already booked in for Friday
With noise tapping on left bank lifters I thought)
So ring them and tell them it's on it's way on a truck !!
Looking at it Thursday
Anyway the geeen flag macanic says it's a cam tensioner snapped off
(I hope he's wrong ) I'm led to believe if that has happened my engine is scrap
Any thoughts or advise appreciated
Post #532933 Tue Aug 15 2017 8:48pm
Bullnogger
Sorry it's a 2.7 sport
Post #532935 Tue Aug 15 2017 8:58pm
Jaggs
When were cambelts done, was oil pump replaced?
2007 is the prime year for oil pump tensioner failing Nanocom Evo
Post #532936 Tue Aug 15 2017 8:59pm
Bullnogger
Cambelts done last year less than 4000 miles done
Yes 2007
Post #532938 Tue Aug 15 2017 9:05pm
Bullnogger
No didn't replace oil pump when I enquiried
was told tested and working fine no problem with it
Post #532939 Tue Aug 15 2017 9:07pm
Jaggs
The oil pump often goes following the cambelt change mine did 15k following cambelt change before oil pump tensioner sheared off, it's not looking good ....... Fingers crossed for you Nanocom Evo
Post #532942 Tue Aug 15 2017 9:13pm
Bullnogger
Ok mate find out Thursday I hope
Keep you updated what the outcome
Is
Thanks for quick reply
Post #532943 Tue Aug 15 2017 9:18pm
Disco_Mikey
Sounds like oil pump. Generally a few K'S after having the belt replaced...
Post #532954 Wed Aug 16 2017 6:53am
Johnski
Should you always change the oil pump then, even on later models (MY2012) when cam belts due for change?
John John
Post #532981 Wed Aug 16 2017 2:11pm
Bullnogger
That's a good question my friend
I wish I had known that so for all of
You Range Rover owners when haveing
Belts done do you need new oil pump
Don't get caught out like me
Post #532998 Wed Aug 16 2017 7:25pm
There was a batch of cars where LR decided to fit a different oil pump casting. This casting is, it seems, weaker than the original but was presumably done to save a couple of quid on the build cost. Following a number of failures, they changed back to the stronger casting. The affected cars are around 2007 I think. The weaker casting seems to be fine until the belts are changed. A few k miles thereafter it has a tendency to fail.
LR have contributed to the cost of a new engine in some cases although I think not all. If you have a complete service history and the mileage isn't that high, it might be worth talking to LR about it. Can't hurt.
There is a lot of info about this over on Disco3.co.uk 2012 SDV6 - it's missing a couple of cylinders
Post #533006 Wed Aug 16 2017 8:25pm
Disco_Mikey
John
It affected 05-08.5MY, and a very small number of 09's
All 3.0 were fitted with the uprated pump Thumbs Up
Post #533010 Wed Aug 16 2017 8:46pm
Johnski
Many thanks for that info Disco_Mikey. Thumbs Up Bow down
John John
Post #533012 Wed Aug 16 2017 8:55pm
