![]() | Home > General > Hope he's wrong |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 ![]() ![]() ![]() |
Sorry it's a 2.7 sport |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
When were cambelts done, was oil pump replaced?
Cambelts done last year less than 4000 miles done
No didn't replace oil pump when I enquiried
The oil pump often goes following the cambelt change mine did 15k following cambelt change before oil pump tensioner sheared off, it's not looking good ....... Fingers crossed for you Nanocom Evo |
Ok mate find out Thursday I hope
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4506 ![]() ![]() ![]() |
Sounds like oil pump. Generally a few K'S after having the belt replaced... |
Should you always change the oil pump then, even on later models (MY2012) when cam belts due for change?
That's a good question my friend
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9092 ![]() ![]() ![]() |
There was a batch of cars where LR decided to fit a different oil pump casting. This casting is, it seems, weaker than the original but was presumably done to save a couple of quid on the build cost. Following a number of failures, they changed back to the stronger casting. The affected cars are around 2007 I think. The weaker casting seems to be fine until the belts are changed. A few k miles thereafter it has a tendency to fail.
It affected 05-08.5MY, and a very small number of 09's All 3.0 were fitted with the uprated pump ![]() |
Many thanks for that info Disco_Mikey. |
