![]() | Home > Maintenance & Modifications > Steering wheel shake |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4488 ![]() ![]() ![]() |
Tyre out of shape
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Thanks Mikey,
Front CV joints, and possibly a diff fault too |
Thanks again Mikey,
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9078 ![]() ![]() ![]() |
Are the tyres the same pressure across the axle? I've found that a mismatch of pressures can cause a vibration. 2012 SDV6 - it's missing a couple of cylinders
Hi RRSTDV8, yep tyre pressure checked weekly always run 42psi all round.
Should be 33psi front and 36 rear... |
Mikey,
DEVON Member Since: 15 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
Excuse my interruption (and ignorance) ' but what is a hub flange ?
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Guyzer
BKHK, thanks for that I'll get he garage to check when the car goes in at the end of the month.
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 190 ![]() ![]() ![]() |
I had the hub give problems a few years ago on an x-trail. A garage replaced the bearing under warranty, and they warped the hub getting the old bearing out. They claimed it was ok but when I checked the run out of the hub it was oval. New hub cured it. |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
I have slight vibrations under braking but nowt I'm too worried about (at this stage).
With my current RRS (L320) there are a couple,of sections of freeway where I have a bit of steering shimmy but on most surfaces it's fine. I think that road surface does make a difference which is annoying as it's hard to diagnose. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
