![]() | Home > Maintenance & Modifications > Front Brembo brake conversion sorted |
tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97 ![]() ![]() ![]() |
Very cool, Ive got all the parts less the splash guards, they seem to be like rocking horse |
sean2204 Member Since: 05 Mar 2016 Location: York Posts: 55 ![]() ![]() |
No I let my local garage do it. They've fitted it with the existing splash guards no problem... |
Look |
Oh right , i was under the impression that the splash guards were to small for the 380m Discs |
They just fit. |
Allycarson Member Since: 04 Jul 2017 Location: Dumfries Posts: 24 ![]() ![]() |
is ther a link to the parts needed do the calipers fit strait on I assume these are 6 pots off the current model rrs |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 407 ![]() ![]() ![]() |
The brakes on my 2010 TDV8 have never inspired confidence and lack low speed modulation. I am still on the original front pads and discs so I have had no need to spend money on brake maintenance. Is it worth changing to the Brembo calipers and discs ie will I see a substantial improvement in braking in my normal driving which is mostly low speed stop start city use. |
Probably not but looking cool is king😎😎 |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
More aggressive pads are your best option to improve brakes for low speed driving. See if you can buy mintex 1144s for your sport. Caliper rebuild or even just a bleed might also help, depending when they were last bled. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5076 ![]() ![]() ![]() |
brembo's won't be a benefit with town driving |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
I think I'd have painted the calipers black first, more discreet and won't show the dirt so bad... |
Just done mine and splash guards won't even look at them
Ron H Member Since: 13 Aug 2018 Location: Aberdeen Posts: 6 ![]() ![]() ![]() |
Hi, can you let me know where you bought your Brembo calipers? I need front set for my L320 TDV8 HSE Sport
There’s loads on eBay. 2019 5.0 SC SVA (Current)
