Home > Maintenance & Modifications > Front Brembo brake conversion sorted
sean2204
...thank you to the forum for helping me source the correct parts.
Brembo calipers and pads 345 delivered
Discs 105 delivered
Fitting 80
The result...
Post #497708 Fri Jun 03 2016 2:02pm
tonywolf
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Very cool, Ive got all the parts less the splash guards, they seem to be like rocking horse Censored Did you fit them? Best Regards
Tony
MY2014 SDV6 AB Dynamic
Post #497744 Fri Jun 03 2016 8:42pm
sean2204
No I let my local garage do it. They've fitted it with the existing splash guards no problem...
Post #497746 Fri Jun 03 2016 8:48pm
Buckster
Look Cool if only i could get a set of 19s over them! Big Cry 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #497747 Fri Jun 03 2016 8:52pm
tonywolf
Oh right , i was under the impression that the splash guards were to small for the 380m Discs Confused Best Regards
Tony
Post #497749 Fri Jun 03 2016 8:54pm
sean2204
They just fit.
Post #497751 Fri Jun 03 2016 8:58pm
Allycarson
Scotland
is ther a link to the parts needed do the calipers fit strait on I assume these are 6 pots off the current model rrs
Post #530951 Sat Jul 22 2017 5:50pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Brembo Conversion Is It Worth It On A TDV8
The brakes on my 2010 TDV8 have never inspired confidence and lack low speed modulation. I am still on the original front pads and discs so I have had no need to spend money on brake maintenance. Is it worth changing to the Brembo calipers and discs ie will I see a substantial improvement in braking in my normal driving which is mostly low speed stop start city use.
Post #531087 Mon Jul 24 2017 12:03pm
Allycarson
Scotland
Probably not but looking cool is king😎😎
Post #531159 Tue Jul 25 2017 5:01am
d-9
Re: Brembo Conversion Is It Worth It On A TDV8
More aggressive pads are your best option to improve brakes for low speed driving. See if you can buy mintex 1144s for your sport. Caliper rebuild or even just a bleed might also help, depending when they were last bled.
Post #531181 Tue Jul 25 2017 2:40pm
brembo's won't be a benefit with town driving
Post #531204 Tue Jul 25 2017 9:46pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I think I'd have painted the calipers black first, more discreet and won't show the dirt so bad... Smile 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #531214 Tue Jul 25 2017 11:02pm
Allycarson
Scotland
Just done mine and splash guards won't even look at them
Post #532762 Sun Aug 13 2017 8:55pm
Ron H
Hi, can you let me know where you bought your Brembo calipers? I need front set for my L320 TDV8 HSE Sport
Thanks
Post #565565 Thu Sep 20 2018 9:26pm
Brit Plumber
There’s loads on eBay. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #565577 Thu Sep 20 2018 10:50pm
