![]() | Home > Faults & Fixes > Another Air con question |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
The pressure sensor reads the high side of the system
Hocks172 Member Since: 01 Dec 2016 Location: Brighton Posts: 84 ![]() ![]() |
Thanks godivanige I will check these tonight and report back with what I've found, appreciate your knowledge. |
Hi here are the live values, these are about 3 minutes after a restart from a 20 minute drive, thanks Sam.
Did you clear any outstanding faults prior to taking these readings and if so, did the pressure fault immediately reappear? 4.8 bar as a static pressure (I.e. Equalised system pressure with the compressor not running) is perfectly fine.
Hi, there were no faults listed as i cleared them last night whilst trying to figure out what was wrong and they haven't reappeared? All seems very strange then if the values are correct is there a relay? or anything trivial it could be?
Check the compressor is turning, with the clutch energised, you should see the centre part of the clutch spinning. If it isn't energised, the pulley around the clutch will be turning with the belts but the centre will be stationary. The clutch is powered by a relay. It's a little awkward to see on a V8, a torch and a mirror will help. Be careful of the fan/belts |
A colleague had a very similar problem to this, and dealer changed the Compressor and it's been fine since. Mind you even if it was also/or a sensor would they tell you?
@ godivanige Thanks very much i'll check tomorrow as I'm currently watching my daughter swim, any ideas where about it is or is it a case of following the pipes? i take it somewhere on the auxiliary belt.
Looking into the engine bay, it's on the right just under the power steering pump.
Thank you very much for that picture i had been looking at the dynamic response pump |
Right by looking at the compressor the outside is spinning but the inside is not?
Hi Sam
Hi Nige, thanks very much for the advise, sorry its took a while to respond. I've had a look at the wiring that all look intact where i can see it.
