![]() | Home > Maintenance & Modifications > MY 2013 RRS Heated Steering Wheel Upgrade |
Lonescout Member Since: 30 Aug 2016 Location: UK Posts: 35 ![]() ![]() |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 ![]() ![]() ![]() |
Hi Lonescout,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5131 ![]() ![]() ![]() |
Steve,
Thanks Col,
Thanks for those words Steve, but I think the problem is I have to much time on my hands these days and can play about with things and delve into bits and pieces.
Hi, Yes it does but it is negligible, but saying that even the leather part only gets warm not what could be described as hot might be because the wheel is quite chunky or slightly faulty not sure, can't even remember how hot original wheel got. Don't really need it down here middle of winter and has been 18 degrees last couple of days. ![]() |
Hi Buckster,
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
The IIDtool *should* enable the heated steering wheel as I have seen the option while perusing the app. As for the airbag, I would guess that simply connecting it back up will enable it after a hard reset. |
Thanks CANROVER for your input |
Cymru001 Member Since: 07 Aug 2019 Location: Newport, South Wales Posts: 33 ![]() ![]() ![]() |
Hi all,
Hi, I didn't need an IID tool for mine. Just plug and play. |
Hi Cymru001,
Hi Evo5man,
No, I had to change the clock-spring, you will be very lucky if you already have the heated steering wheel clock-spring fitted. But even with changing the clock-spring, I still did not need a IID tool. Just plug n play for me |
Great news. Thanks for letting me know. |
